Vortexbox/mpd + nDAC vs NDX or NS5XS
Posted by: Tim Watkins on 03 November 2011
Any help greatly appreciated.
I don't have a NDX or NS5X at home to compare with my VB.
I have used my VB out of its USB port through USB/S/PDIF convertor.
To me the Naim DAC has a much more appealing sound than the bear NDX as there was a huge improvement when Naim added its DAC to NDX at a recent demo.
I'm delighted with my VB. I don't use it in the way described though, I use it as a source for a W4S modified Sonos ZP90 to feed the DAC. It sounds pretty good to me. Nothing I heard at the demonstration would make me want to change this set-up.
My current VB is on an old Sony computer: I intend to upgrade this soon.
Of course, everybody hears things differently so I can't be sure others will agree, but if I had to choose then I'd go VB into Naim DAC, well that's what I did choose so I would say that.
I haven't heard the 5X though.
Also, I imagine that the NDX doesn't have a fan and is totally silent. My current mini-itx box (which runs VB) cost £220 but has a cpu fan, a case fan and a spinning hard disk. It isn't particularly loud but making it quieter is on my todo list and is worth bearing in mind. You can get fanless + SSD mini-itx boxes, which trades the cd ripping / storage for the silence of having no moving parts, naturally for more money. Then there is a price/feature trade-off on the scale up to the NDX (e.g. the NDX has a display, IR Remote and looks nice / fits with other naim gear but costs more).
Steve.
@Tim - actually Vortexbox can operate in 3 different ways at present.
1. As a network server for UPnP, DAAP (itunes), Sonos, and Squeezeserver.
2. As a HDD based player using MPD (like an HDX)
3. As a renderer/player streaming from another Vortexbox or UPnP Server - Sonore's Vortexbox Orbiter (in fetching Naim half size black aluminium to go with the Qute) would be the latest example.
@Guy - your setup is exactly what Andrew at Vortexbox initially envisaged - a great way to serve to Sonos or Squeezebox devices.
@beeka - the trick is that you can put VB in almost any intel based server you like - silent or otherwise cheap or ludicrously expensive. If you are going to use it as a HDD player consider the use o SSD for the OS and the use of really high end sound cards like Lynx.
Tog
