Streaming Options
Posted by: raife on 07 November 2011
Hi,
My system consists of
CD5xs
SuperNait
HiCap
FlatCap2
Should I use the digital or analogue output from CD5xs?
I wish to add a streamer or hard disc player but I'm completely confused!
Should I sell the CD5xs and buy a HDX?
Should I buy a Unitiserve?
What benfits would the NDX / ND5xs give over the Unitiserve?
How does the CD5xs + Unitiserve + SuperNait stack up against the SuperNait + HDX?
Confused and that's without asking about the nDac.
Posted on: 07 November 2011 by Mr Underhill
Hi Raife,
I'll have a go:
In essence Naim has three digital lines: Servers; Streamers & DACs.
Servers
These will:
1. Rip your CDs, locally or remotely;
2. Serve up an uPNP music stream;
3. Give you an Internet Radio; and
4. Render your remote/local files to spdif for feeding a DAC.
In the case of the NSxx and HDX the servers also have an onboard DAC, meaning that they can output what they are rendering into a pre-amp.
Streamers
Really these are renderers, they will:
1. Consume a uPNP data stream and feed the output via SPDIF into a DAC; and
2. Give you an Internet Radio
In addition they have an onboard DAC, so they can be plugged direct into a pre-amp.
DACs
There is one, which can be viewed as three, that is:
1. Bare nDAC;
2. nDAC + XPS; and
3. nDAC + PS555.
As to your options:
Do some searches, or look at some of the current threads, and you'll see a wide range of opinions.
My personal advice would be to get to a dealer and have a listen.
I would agree with a number of people here that the nDAC is the VFM product in the range, and very easy, if not cheap, to upgrade.
M
Posted on: 07 November 2011 by Guido Fawkes
+1
I haven't bought a UnitiServe and don't intend to; nothing wrong with it, just too expensive for me and I can achieve equally satisfying results from a more modest approach. However, the Naim DAC is a camel of a different colour; stunning piece of kit. As good as anything Naim has brought out.
