n-serve instead of n-stream
Posted by: LarsDK on 08 November 2011
in an US>NDX setup, does anyone know how i can control via n-serve app, which just seems so much better. Must require a specific setting for NDX, but dont which one...
thx
lars
Posted on: 08 November 2011 by KRM
You can't control the NDX using the n-Serve. You can use it to control the Unitiserve, but if the Unitiserve is not directly conected to the hifi via a digital cable the replay functions won't work and there's not much point in connecting the Unitiserve to the hifi if you have an NDX unless you have two systems. Mine is connected to the system via ethernet cable and switch. I use n-Serve for monitoring ripping progress and I could use it to create playlists which can be accessed by n-Stream. In reality I usually create playlists using eLyric or Plugplayer or moan about lack of n-Stream on-the-fly playlists here.
Keith
Posted on: 08 November 2011 by LarsDK
thanks for clarifying keith. not much to do about it then, except waiting for next app release
lars
I'm afraid so Lars. On the plus side, the NDX served by the Unitiserve is a joy to use. Plus, I think we all feel a lot calmer since Tom clarified Naim's plans and managed our expectations.
its an amazing pair, totally agree. where can i read Tom's comments on naim's plans?
Check out "n-Stream updated"
