Digital cable length
Posted by: naimUnT on 08 November 2011
That won't be a problem. It's only TV sound anyway so nothing to get too hung up about. Any reason why you can't run Toslink ?
James
how about digi straight from your STB to the NDX? Why send it to the TV first?
Keith
why is that?
poor quality opto domestic cables maybe poor but with high quality fibre , you wouldnt tell the difference, its also better over distance and isolates any unwanted noise
too much codswollop from expensive cable manufacturers
It's worth remembering at radio frequencies, losses are mostly down to central conductor size in coax and sizing and quality of dielectric. (the material between core and shield).
Simon
why is that?
Good answer > codswollop from expensive cable manufacturers
I prefer Glass Toslink to Electrical when a computer is connected through to a DAC.
With the W4S Sonos it doesn't make much odds with Electrical sounding as good, but certainly not better than a good Glass Optical.
The Wireworld Glass Optical and the no longer made TCI Glass Optical are excellent cables. I'd avoid using more than 1m if possible, but I can't see why a longer length would be so bad.
I'm not keen on plastic ones, especially ones that are plastic and expensive.
Don't pay a fortune - high price Coax is not worth it IMHO.
In my last job I sold VERY high-end diamond abrasives (3M Microfinishing Films) to a premier boutique manufacturer of fiber optic cables and terminations. Trust me that that the material used has little to no effect on transmission. The glass cables are easier to polish. That said, they are not appropriate for certain applications given the likelihood of cracking.
When I asked him why one would use one over the other they said glass is cheaper for them so money would be the overarching reason for selecting glass. But it all depends on the spec for the terminals and sheathing. Also how many fibers are bundled into a single cable etc.... It is all spec'd by engineers smarter than any of us.
Even in glass cables there is a plastic core. Otherwise the light would not transit well. It needs to reflect off of the dissimilar surfaces.
Basically I was told that in a single toslink cable used for a single stream of audio, it matters not what the material is. What DOES matter though is the quality of the polishing of the cable and getting the core perfectly centered and the light scattering consistent etc...
In a vacuum, glass vs all-plastic as a substrate doesn't matter. Unless of course you need tight bends, then plastic is better.
Whether or not cable mfrs use plastic, and maybe shoddy polishing, on their lower end cables has nothing to do with the material used.
-Patrick
Thanks Patrick - I upgraded from a plastic cable to a TCI Glass Optical and it did sound a lot better, but it may be the quality of the polishing, connectors and sheathing rather than merely its use of glass, as all of these were different. The TCI cost £70 and is the best digital connection I've found. The Wireworld Super Nova is very good, but is double the price. Unfortunately, TCI no longer makes the one I have.
All the best, Guy
Any way as i said the big gotcha with fibre optic for SPDIF is he micro phonic induced jitter, so me hanical decoupling and lossy sheaths are the order of the day.
Simon
I do presume that some here are not smart engineers, myself included. sorry.
