Naim Unitiqute or to save money for ND5 XS?
Posted by: Vicca on 08 November 2011
The baseline is in the title. So, as a happy owner of a Naim kit (NAC122/NAP150) I'm struggling to buy or not to buy Unitiqute, primarily because of reported issues regarding unexpected non-responsivness, while listening to iRadio. I would fed my DAC (which is now a wonderful M2Tech Young) instead of CA NP-30, which I have been using for some time with no problems so far, wondering what one might expect in terms of SQ, jumping up at Naim's courtyard. I suppose a lot...
However, is it a Upnp server choice for Unitiqute limited? Are there any issues regarding ND5XS, similar to Unitiqute, and how easy one might expect to install and run server via qute or ND5?
So far Twonky is working fine on my CA as well as radio.
And I am listening to radio lot more than I thought I would and decided to definitely experience something rather more sophisticated than my current setup, which Naim definitely is. Speakers are Focal JMlab MiniUtopia.
Please don't thow away Unitiqute option right from the start, as I would be using it primarily as a streamer through its digital out. And at 1st it seemed so cozy and easy to setup/use.
Kind regards
