Is it possible to play the rolling stones 24 bit 176 kHz files from hd tracks on the latest spec ndx?
Jon
Posted on: 18 November 2011 by Guido Fawkes
No it has a Rolling Stones detection chip that prevents this, but there is no problem with other bands especially on the those on the Naim label - sorry only joking
Yes it will and I'm sure they'll sound great almost as good as my vinyl copies (not so keen after Exile, but up until then thought they made great records).
Posted on: 19 November 2011 by rich46
the hd tracks stones catalogue the ep download is alittle bright. the others sound very good on the ndx5, if you are a fan of the stones . they all are at 192 or 88 k problem too expensive
