How to change album art on HDX?
Posted by: Brando on 20 November 2011
Hello,
I would like to know how can I change the album art on the HDX internal database? I have many music files stored on USB flash storage inserted in the device but most times the album cover doesn't show. I tried with coping album art in the folders where the songs are but that didn''t work... Maybe the file should be in some determined format or something should be done on a computer first before the songs are copied...
Is there a solution to this problem of mine?
Btw, I bought my iPad last week and the n-Serve app is just GREAT! When I was considering to buy the HDX two years ago the B&O Beosound 5 with similar screen and some kind of wheel which is used to control it was the alternative to HDX. But now, after all the improvements (the internet radio and the app) I wouldn't even consider B&O!!
Thanks!
