Gigabit switch?
Posted by: MangoMonkey on 21 November 2011
Just wondering. Is there any value in using a gigabit switch rather than a 10/100 fast ethernet switch when connecting the streamer to the NAS?
I have been recommended to get a Gigabit switch over a Fast net one. Future proofing maybe?
What I would recommend however is choosing a switch that senses the Ethernet cable length and reduces the drive voltage as appropriate. Some of these devices do also support 1000BASET. For example Netgear have a variant of this on some of thier switches called 'Netgear Green'. Not only does this save power consumption but also reduces propensity of EMI from the Ethernet.
Simon
Dear Simon,
Thanks, that's helpfull. I am probably wrong, but I thought that a GigaSwitch would enable much faster speed of for example FLAC's when embedded in a streaming network. Am I wrong ?
Therefore hidef wavs and FLACs really are comfortably down within 100BAST and CD and some hidef is also good at 10BASET, which is rather old fashioned now.
Therefore all we are doing using 1000BASET if our Naim gear supported it is sending little bursts of frames with large gaps of nothing in between. With 100 and 10 BASET the gaps between frames (or group of frames) get progressively shorter. When there are no gaps left, the link is full up.
My final point, is that enabling a port to 1000NASET is simple, it's a standard chipset technology. However the the overall throughput of the switch is more relevant. Ie the amount of data it can switch across all ports. Cheap switches are often low bandwidth limited, and so it would reduce the effective data throughput rate if there was load on the other ports of the switch.
Another way of looking at it, is your broadband could be at 6Mbps.. In the middle of the night your surfing performance is great, however in the evening your performance slows down because of congestion in the uplink network from your ISP, but your broadband is stll at 6Mbps.
Simon
Does the NDX support gigabit Ethernet? The manual doesn't mention any speeds and I've not got a gigabit switch at home to try it with.
Simon
So my Cisco-Linksys WRT54GL Wireless-G Broadband Router is good enough and up to the task?
Simon
Iver
Most definitely - nowt wrong with that, good choice. You should check your firmware is at least a revision 4.30.5 which I suspect it will be.
Now I'm waiting for somebody who has a Juniper router/switch like me to tell me they can hear a difference between JunOS 10.4 and 11.1 - HiFi Critic perhaps ![]()
What ripping system are you using?
Of course for large data transfer one can activate jumbo frames if your equipment supports it that increases throughput for a given network speed.
Simon
I would never rip directly to nas, I always rip locally then copy over.
I get throughput of around 50-60MB/s mac to mac, 50MB/s down and 20MB/s up from NAS.
These figures are just not obtainable from TBase 100, and considering the reasonable price of gigabit switches its a bit of a no brainer really.
I find that even at 18x ripping speed dbPoweramp isn't able to copy the files to the NAS quickly enough if I use 100mbps Ethernet so gigabit certainly helps here. You can tell by the way dbPoweramp has a maximum of four tracks in progress at any one time and ripping stalls until the first ripped track or the four is copied to the NAS. For the original question 100mbps Ethernet is sufficient as the streamer doesn't support a higher speed connection. I think you'll also find that most switches bought recently can forward packets at a rate well in excess of what a Naim streamer needs.
What benefit does ripping locally bring?
FYIW:-
I have just fitted am Netgear Gigabit switch GS 108. I was having an issue with juddery performance when playing iTunes from my NAS, (BT HH3 providing the switch).
This seems to have been fixed now, with the gigaswitch.
For the very reason you mention above. Same with DVDs when ripping locally its super fast then you just batch drag them to the nas, this prevents and risks of network issues in the ripping process.
I believe HDXs etc do the same when a store is set up, i.e. rips locally then copies over once done.
Using Gigaethernet is useful for moving big blocks of data around if both peers support it, for streaming it's an overkill and not supported by Naim. For that matter if you are sending big files to and from a NAS then high speed disks (SATA 7200 Baracudas) and jumbo frames (less network overhead) are the order of the day.
I must admit data transfer of 50 MBps is rather phenomenal sustained rate to a consumerNAS, but if it had a vast cache RAM then I can see it working well. My Netgear NAS has only a max sustained transfer of around 8 MBps.
Simon
I never said too I said from, copy to the NAS is typically around 16-20MB/s on ethernet.
For day to day LAN duties its silly basing your network on the lowest common denominator, especially how cheap it all is. Might as well get gigabit as 100.
I am measuring this with iStat pro which measures throughput ad hoc, and I can except therefore I am not getting averages, I need to do some real world measurements for a given file size. Certainly I have never seen a copy in dropping below 30MB/s so its at least that. The TS412 on netbuilder is throughputting at 45MB/s
Having set up a 100 speed network, the differences are really rather marked.
On wireless with a the top o the line asus RTN56u I get 8MB/s to and fro, give or take.
Simon
I guess I was was wanting to counter those who justifiably don't want to understand the where with alls, didnt think just because a switch has an extra 0 it will make thier streamer sound better and bin perfectly suitable equipment if it's working already.
Simon
Mine sounds better , but that's because it's not "dropping" parts of the music.
Haha yea fair point.
I got a 20 port us robotics gigabit switch on broadbandbuyer a couple of years ago. I think there was a mistake on the website because it was 60 quid, and I can me across it by accident, suffice to say I snapped it up. An hour later it was 144 quid.
