Asset is not seeing some tracks
Posted by: AMA on 05 December 2011
Why?
FYI: those are regular flacs. The tags look very common.
When I drag these flacs and drop them to Kinsky Desktop my KDS just plays them OK.
Posted on: 05 December 2011 by Simon-in-Suffolk
Have you forced Asset to do a rescan?
S
Posted on: 05 December 2011 by AMA
Yes -- didn't help.
Posted on: 05 December 2011 by Dustysox
Clutching at straws here..
Any boxes ticked with "Exclude Audio Type?"
Posted on: 06 December 2011 by mrspoon
See if the tracks are held in Asset, by folder & filename browsing (under Advanced Search >> )
Posted on: 06 December 2011 by rich46
is there option of detect changes in scan menu
Posted on: 06 December 2011 by AMA
Thanks all.
Rescanning did not help but rebooting PC followed by rescanning the library resolved the issue.
So it's not about Asset -- this is a local OS issue.
I still not happy these things happen.
I wish I have a dedicated hardware uPnP server which just works and works...
Posted on: 07 December 2011 by Simon-in-Suffolk
AMA, what is the OS? Have you tried WHS? It seems very stable. The only issues I have is occasionally asset doesn't recognise new rips, so I just hit rescan, and asset quickly finds the additions and starts streaming them. I am using a beta version of asset, and had no problems with the official release. Simon
Posted on: 09 December 2011 by AMA
Simon, OS means Operational System (which is Windows 7 in my case).
That was a clear Windows glitch which has nothign to do with Asset.
After rebooting PC and rescanning the Asset it all works just fine.
I'm sorry to make a mess on a forum.
Posted on: 10 December 2011 by Simon-in-Suffolk
Ok thanks, and good luck
Simon
