NARCOM AV Remote not working the AV2.
Posted by: tonym on 12 December 2011
For some reason my AV remote controller has decided to stop controlling my AV2.  The other side of things, i.e. the CD, Pre etc. works fine & the Philips "Pronto" remote I mostly use for volume, processing and source selection also works OK, so I'm pointing the finger firmly at the AV2's remote.
Is there some way of resetting it? Perhaps the remote keyset has been inadvertently changed? (I suspect outside fiddling...)
Posted on: 13 December 2011 by Trevor
The AV2 may have had the set of remote codes it responds to changed from the standard. I think there is something about changing them using the AV2 buttons in the Manual
Posted on: 14 December 2011 by tonym
Thanks Trevor. I've had a look through the manual but other than resetting the AV2 to factory defaults there's no mention of resetting remote codes. Besides, the remote codes programmed into my Pronto still function OK, so I guess the Narcom's gone up the Swannie.
Posted on: 14 December 2011 by Mike1380
Assuming your remote is the black one with a red circular standby button, this should do the trick: https://forums.naimaudio.com/di...ent/1566878606539265 It doesn't specifically refer to the AV2, but the AV portion (step e onwards) of the n-Vi's procdure on this page uses the same codeset, so this will work. If you have the older remote with rectangular buttons then I guess it's time to call Steve at naim.
Good luck
Mike
Posted on: 15 December 2011 by Richard Dane
Tony, resetting the remote should cure the problem. Looks like Mike has given you the FAQ link.
Posted on: 15 December 2011 by tonym
Ha! Many thanks chaps, that's done the trick! Flushed with my success I think I'll go and reset the wife.
Posted on: 15 December 2011 by BigH47
Good luck with that!
I'm not afraid of her Howard...
No nervously looking over shoulder emoticon then?
