Unable to put unitiserve into standby
Posted by: maze on 13 December 2011
If any one can throw any light on this, I am unable to use the naim logo to put my serve into standby.
The manual tells not to just switch off from the rear on off switch and to first touch the naim logo screen to activate standby mode.
Posted on: 13 December 2011 by GerryMcg
I assume you have pressed the log button continuously for 5 seconds.
Gerry
Posted on: 13 December 2011 by maze
I assume you mean the naim logo? Yes I have.
Posted on: 14 December 2011 by Benoit
Hello,
My experience is that sometimes you have to press a little bit harder. Try with a wet finger as well. With or without shoes (I don't know if is is a capacitive switch or something else...)
If all fails, it may well be defective
Good luck
