Feeding DAC - Sound quality
Posted by: pz on 18 December 2011
Hi Mates,
I have DAC+XPS and naim amplification.
I am about to decide how to feed the DAC for the best possible sound quality.
Possibilities are:
1. Buy an nServe and use it as a HDD misic player into DAC.
2.PC laptop + Decent interface into DAC
3. USB straight into DAC.
Which option could give the best sound in your opinion ?
Any post welcomed.
May I suggest an option 4, an ND5 XS with a NAS, similar in price to your option 1 but with the potential for better sound and great usability.
Richard
class="quotedText">
Richard
+1. See if you can demo an ND5 XS. Helps a lot if you already own an iPad, as it is pretty much a mandatory component for controlling a Naim network player.
Good luck.
Hook
Buy a new Mac Mini and use a Wireworld supernova Optical Interface to connect it to your Naim DAC/XPS2 - stunning sound quality - it must be a new one with the low jitter optical out. Very quiet, flexible and will offer a bit perfect service in to you Naim DAC. Ideally buy the one with 256 GB SSD and 750 HDD, it will hold around 2000 CDs worth of lossless CD quality music. Use iTunes with Bit-Perfect to optimise it.
Alternative, as recommended by Richard and Hook is ND5 XS and Vortexbox.
You'll need some network skills to set this up.
The Vortexbox is as easy as it gets when it comes to serving music.
In both cases uses an iPad as a remote
The SQ from both options will be as good as it gets.
ripnas/nds5 streamer/ndac/x5power supply cyrus 300 feeding quads . forget cds . control number 1 ipad......stunningly tops
HI,
Why should nd5X be a better options than any n-serve from a technical viewpoint.
As I read the forum people choose a source for the NDAC based on price, brand, or simplicity of use.
Like others on the forum I hope that sometime in the future Naim will produce a streamer/DAC in reference quality. Until then I am very satisfied with my ns01 0ndac +spsx2. I would probably have investigated the cheaper alternatives if I had started from scratch, but I traded in my cd s3 for the streaming solution.
Claus
The n-Serve into the DAC was the best source I'd ever had, until I inserted the UnitiQute between the two. I would imagine it's even better when inserting an ND5X. Others have found that the digital out on the nServe is not optimal. My experience in replacing it with the dig out on the Qute supports this.
Please note however, that the n-Serve & DAC remains a stunning combination. It's only when I started to compare that I heard the difference. But it just seems like overkill to use an ND5X, a Qute, or an NDX solely for its streaming function.
An interesting alternative would be the Cyrus streamer. A review in HiFi Critic pegs it as superior to the Qute. But then that's just a hifi reviewer's opinion ![]()
Jan
Hi Mates,
Thanks very much for replies got so far.
I forgot to mention that I have NO (wired)
internet access where my system is setup ?
Please take this into account.
Happy New Year To Everyone.
How would you insert a ute or anything else between n-serves and ndac without using the digital out that is supposed to cause the degrading quality?
Like most people here I have lost my way in the Naim digital hierarchy, but someday the ultimate streamer plus NDAC, or maybe an upgrade serve will come along.
Claus
How would you insert a Cute or anything else between n-serves and ndac without using the digital out that is supposed to cause the degrading quality?
Naim UServe is also a UPnP stream server, so you can bypass the digout if you have a stream client on the other end.
I hope this thread is of some help: https://forums.naimaudio.com/...
Claus
Aysil
I had a DAC/XPS combo too and spent ages trying to decide how best to feed it.
These are the options I thought about. Every option is a trade-off between price/utility/quality/function, none perfect for me....
Memory sticks - pretty good sound, but a hassle
PC iTunes/Airport Express? Tried it - quality rubbish (though some people had better results than me)
Macbook/Toslink? Tried it - OK - not as good as memory sticks.
UnitiServe? - better sound than memory sticks but expensive as a ripping solution
NDX? - great but expensive and has a redundant DAC
UnitiQute? - neat - but redundant amp
HDX? - expensive, US does what I want for less
But in the end I went for a UnitiServe. I am very happy with it.
Some people will say there are better ripping/storage solutions (eg Vortexbox) but really I got it primarily as a streamer, with added ripping/storage capability. I expect that downloaded and HD music will supesede CDs in the next 5 years so I also envisage the US being my way of storing my CD collection.
Some people will say that the dig out is not optimal - but it is still VERY good and better than memory stick.
But - had the ND5SS been out at the time, I probably would have gone with that. It is easier in a wireless environment - you'd need a separate wireless bridge for the US. (I ended up running an ethernet round the house to the hifi which took me a couple of hours but was well worth it).
Also I gather that latest MiniMacs have improved optical outputs with much less jitter - might be worth looking at.
I would say it serves the same function and the SQ is equivalent.
The advantages of the US are it's Naim hardware and software and has Naim support.
The VB is flexible in that you can choose hardware to suit
The new Mac Mini is a very good solution as it's optical out is vastly improved from previous Mac incarnations.
A PC/Mac with a Juli@ sound card is yet another option
Lots of options
Martin, this is an excellent post with a good summary of all the alternatives!
I agree, there is not a just perfectly matching partner in the Naim range for the nDAC. In spite of the fact that nDAC has been one of the best selling products, there is not a reasonably priced stream client without redundant dac and amp in the range.
