AV2 needed resetting yet again
Posted by: Dungassin on 26 December 2011
Damn and blast.  I entered the setup routine on my AV2 last night just to check out on Chris Bell's problem.  Spent the rest of the night until beddy-byes watching off-air material on my DVD recorders (hence stereo only)
This moring I put in the Avatar Bluray, and no multi-audio!  Decided I must have upset something in the AV2 setup, but the AV2 wasn't responding properly to the remote.  Finished up resetting the AV2 and doing the setup routine from scratch.
Sod's Law, I suppose ...
Posted on: 26 December 2011 by Richard Dane
The AV2 can be rather sensitive to unstable voltage and also whatever is connected to it. Mini power cuts, of which I used to have a number every day could cause constant setting loss. I tended to ensure that cheap and nasties like TVs and the like were connected via an optical connection.  Anything that floats at half mains voltage or connected to cable feeds is best isolated because it can scramble the AV2 settings and lock it up given half a chance, requiring a re-boot or re-set.  Static shocks also tend to wipe settings too.  I haven't tried lifting the signal to earth connection, but might be worth a try if the problem persists after taking all other precautions.
I think some work was done to try to lessen the AV2s sensitivity to this sort of thing so later post casework revision AV2s (or earlier units with revised motherboards and later Gen 6 processor board) may be better here, but I can't say for sure.
Posted on: 26 December 2011 by Dungassin
Thanks.  I think I already knew most of what you say.  Alas, I seem to need to reset/reprogram my AV2 every 2/12 or so.  That's why I keep a printout of my settings. Don't even need to refer to the manual any more to do it, either!  Really just nuisance value.
