Uniti V3.9 flac file ends earlier after update
Posted by: Stephan K on 28 December 2011
After updating my Uniti to the latest firmware, some flac files I play via USB stick will end a few seconds earlier than before.
Have someone seen the same problem?
I will try to play these files via UPnP.
Posted on: 28 December 2011 by Stephan K
I found out something weired.
I put the USB stick into my PC, played the file with VLC player, which worked correct.
After tha,t I run checkdisk, no errors were found.
When I use the USB stick now in my Uniti, the song is played correct.
