aif and alac with uniti
Posted by: balma01 on 31 December 2011
I've just upgraded my uniti to version 3.9. The question is: does aif and alac files are  supported with this version?
I did 4 experiments, here the results:
1) song1.m4a (alac) from asset upnp is played
2) song1.m4a (alac) from USB stick is UNSUPPORTED FILE FORMAT
3) song1.aif from asset upbp is played
4) song1.aif from USB stick is played
The manual says that the 2 apple files are not supported so I do not understuad the results from 1), 3) and 4)
Please consider that may asset upnp is NOT configured to stream alac or aif to any other format.
Posted on: 04 January 2012 by murkku
ALAC support requires the 24/192 streamer board upgrade.
It seems some ALACs cause NDX to jam just like early FLAC support did (caused by large attached images etc. metadata). Asset UPnP transcodes to WAV so I can wait for firmware fixes.. Again
