24bit 44.1kHz File Issue
Posted by: funkyand3 on 01 January 2012
All files are 24bit at 44.1kHz sample rate, which may be the issue. I've only purchased other 24bit albums which are at 96kHz and all play fine.
Will the upgrade help with this? Has anyone else experienced these problems? I've already contacted Linn who reported that they have had no similar complaints.
Set Up details are:
NDX-0225 version 3.06.00
NAS drive - QNap TS-419P firmware version 3.5.2 build 1126T
Media Server - Twonky version 6.0.34
The fact that 96/24 files play fine confirms in a practical form the specs which say 24 bit is supported.
I am assuming the downloads are all FLAC files, not that this should have any significance since they should be converted in the NDX for replay to WAV but you could try converting the errant FLAC downloads to WAV on a PC first ( Audacity for example can do this for you) then loading them to your music store.
Alternatively you could ask Linn to allow you to download said files again on the premise that all did not go well the first time and see if that helps.
regards
Geoff
I wonder if this is an album art size issue.
Might be worth checking, perhaps remove the artwork if embedded and see if a track will then play again. I don’t know if this issue has been resolved in the new software, but is known.
If this should be the issue simply resize the image and retag the files.
Peter
Edit: Remember to rescan your files on the NAS after changing artwork.
I aim for 500x500 pixels with a file size not much more than 200kb, although many of my files are much smaller than 200kb, and still look fine.
Peter
James
Great to hear your files now work OK.
I would not be surprised to find that this is an issue that is fixed in the latest software as it has been on the to-do list; hope so. I now have the adaptor to enable me to apply the update, so a job for tomorrow I think.
Peter
Dave,
Can you consider making your album covers available?
I grab covers via Google - but frequently they are smaller, and poor quality.
If you do could you start a new thread with a URL - perhaps others would contribute.
Thx,
M
Simon
Paul
You need a Windows PC to carry out the update together with an RS232 cable or a USB to RS232 adaptor. You can download the software that contains instructions on how to carry out the update and also a link to a company that can supply the correct adaptor should you need one.
Download the software from http://www.naimaudio.com/userf...eamer-update-3.9.zip
You may also like to read this thread, which discusses people’s experiences when doing this. https://forums.naimaudio.com/di...nt/12688757299296805
I have just updated my unit, the only issue I had was that I needed to shut down the Firewall on the PC to enable the unit to be connected to. This is not unusual with my setup.
Speak to your dealer if you are unsure.
Peter
I'll start a thread and see if any experts share an opinion.
No it only only works with windows. You could try a mac windows emulator or borrow a neighbough's windows laptop.
Simon
Chaps
As Simon says - update the firmware - that cures most ills
also
I found I had a problem with one of the Linn albums where the album title was so long - the Marconi Union "Beatifully Falling Apart ..." that I had to shorten it - I suspect the path name was too long. It is possible the new firmware fixes this as well though - but if you still have a problem - it is worth a punt.
Andrew
