Question in buying a used Qute
Posted by: QoS on 04 January 2012
Hi everyone, I am buying a recently used Qute (june 2011), saving 45% from a new one. I have seen the posts related to the Qute upgrade (and its highcost) and what worries my most is the Apple Lossless compatibility.
I have a good amount of Apple Lossless files, that I can convert to wav or flac, but would it be the same in terms of file management through itunes (on which I am heavily depending on)?
And can I just stream my apple lossless from my Mac to the Qute?in this case will I loose the Dac capabilities of the Qute?
I am not into sacd so I do not care about 256khz streaming.
I am buying music from itunes but that as far as I know is low quality non Apple Lossless
What is your advice?
Thank you
Thank you
