UnitiQute/Airport Express
Posted by: bigsplice on 19 January 2012
Hi All
I am experimenting with itunes/spotify wireless via airport express into my qute. It all works
Fine with an analogue (3.5 to 2x rca) but im wanting to connect digitally and have tried with QED digital optical cable with adaptor on APE end. No sound whatsoever, im not sure whether the APE is faulty, the adaptor is faulty or some settings are wrong. Im gonna try another cable but was wondering if anyone out there has had similar issues with an Apple Airport Express
Posted on: 22 January 2012 by horse
hi, this should work fine, i would first check with another cable just to rule that out, do you need to enable the optical in on the qute somehow?  might be worth checking the manual?
Posted on: 23 January 2012 by garyi
Set somemusic going and check the end of the cable to see if there is a red light.
Posted on: 23 January 2012 by bigsplice
No red light showing but dont know why!!!! :-((
Posted on: 24 January 2012 by Eloise
Probably the adaptor...
I'd mosey on down to the online store named after the large South American river; and pick up for a few quid a Mini-TOSLink to TOSLink 'cable'.
Eloise
