N-stream on Ipod and Unitiserve-SSD
Posted by: kTana on 20 January 2012
Hi,
had anyone ever being using the n-Stream app version 2.2 (on Ipod with ios 5.01) to connect a Unitiserve-SSD (system version 1.6b)?
Both devices are in the same network. I already tried to configure the IP address of the Unitiserve in the n-Stream app but it can't find the server anyway.
I've noticed an abnormal behavior: sometimes when I click on 'Setup' when the n-Stream prompts 'Streamer not responding' the app just shut down. It's not systematic. Of course I've tried to uninstall and re-install the app but still that strange behavior and no way to connect the serve.
Thanks ahead for your help,
FranÇois
Posted on: 20 January 2012 by Jack
Francois......you should be using n-Serve with the Unitiserve to control it not n-Stream
Is that problem?
Posted on: 20 January 2012 by Bart
Is that problem?
+1  n-Serve is the app for the UnitiServe
Posted on: 20 January 2012 by kTana
oups, indeed it's much better using n-serve. Sorry for the annoyance.
Thank you guys
François
