Mac book pro and ndac
Posted by: stuart on 26 January 2012
Stuart
I recommend you do not get a Mac. Go with another solution. Linux if you despise Windows.
-p
Stuart
Hi Stuart, have a look at this thread, answering all your questions: https://forums.naimaudio.com/di...nt/13111295368076312
If you want to download material from Naim they have a download manager that requires Adobe Air, and I am not sure it exists in a mac version? You can still download tracks but you will have to download each track individually.
Many on the fourm will say that a Mac is preferable to a cd to play music through the ndac.
Forget the OS wars they are not important, since sollutions exists for all the major OS.
Claus
Hi Stuart. I second Iver's suggestion that you read the thread that he started. I also suggest that you do lots of reading/research into setting up, conversion and finding the right software and hardware for you and your wife. It is also important to take straight up recommendations with a little bit of a question mark, you may have noticed in some of the postings people have their favourites and are almost evangelical in the promotion of their view of things.
Most important of all is to make sure that you wife is happy with the choices made. I find that ensuring domestic harmony helps my interest in hi-fi.
Having said the above I use a Naim DAC and a Mac Mini feeding 282 Pre Amp=> 250-2 Power Amp => Alleae speakers. Unfortunately I can't say anything on 24/196 files but I play my 2K+ CD's ripped in AIFF through this system with great satisfaction.
Good luck and enjoy whatever you choose.
Adobe Air is available on Mac. The latest is 3.1 from the Adobe download site.
The good thing about the Mac is it just works.
One of the sources I use with my nDAC/PS555 is a recent (2010) MBP. Sound quality using a cheap optical cable is great! I am sure it can be bettered with a real glass fibre cable but it's very good as is. I do prefer the M2Tech HiFace/Naim DC1BNC connection though. It sounds truly superb. I don't have my CDX2.2 at the moment to compare but I don't think it will sound much better. Recently downloaded Naim's HD "Meet me in London" album, my first experience with 24/192 tracks and it blew me away, simply amazing!! Downloaded it straight into iTunes without installing Naim's Download Manger. The files are WAV so you need to fill in the metadata yourself. Only thing I did not manage was to include the album artwork, for some reason it just won't show?? It's odd because I managed to insert artwork with all CDs I ripped in AIFF, maybe it's to do with WAV not keeping artwork in iTuens? Dunno.
SQ in order of preference into nDAC/PS555 would be:
1) CDX2.2/DC1BNC and MBP/HiFace/DC1BNC (pretty much on par)
2) Sonos ZP90/DC1RCA off MBP via Ethernet and MBP optical out (very much on par)
3) Sonos ZP90/DC1RCA off MBP over WLAN
Of course Sonos is limited to 16/41. Still like to use it though, their control apps for the iPad and iPhone are both excellent, rock solid and a joy to use!
It would be interesting to know but one thing is for sure, the optical out of the newer unibody MBPs are very good!
Once you go Mac, you never go back!
If you want to use this new computer as a server from which to stream music to a player, or directly to the Naim DAC, then you might want to do some more research. But in my opinion, you likely would want a piece of hardware that is dedicated to that task, rather than a laptop that gets general use in the family.
It is the current mania over UPnP that complicates the issue and for that you are indeed better off with a Linux setup. Apple still have some way to go with AirPlay.
Mac too tricky to plug into a decent dac - I don't think so.
Tog
i did
i did
Patrick, you are certainly not alone. I also returned to windows after using mac for a few weeks. We, windows users are usually not fanatics, and don't even talk about these things. So, let's not bother!
that went right over my head...... REM reference?
Claus
I can confirm that you can download from the Naim record site using a mac. Adobe Air is available for a mac.
Buying a macbook pro was the best thing I ever did in terms of computers. Its great.
Do they even outfit their computers with Firewire these days?
The trouble for pc users is they expect to see a serial port on the back of a computer, really. Move on
Its all at thunderbolt now.
The WD HDD look as if they might sell well.
@Patrick - you've got to admit the Apple 27" display is a bit gorgeous
Tog
I have Thunderbolt on my new Mac ( well actally Mrs S-in-S' Mac, i personally prefer Windows and IOS ) but apart one of Apple's monitors which looks rather nice albeit pricey there appears not much to use with it, I wonder if it is proving difficult or expensive to develop for...
I get the Thunderbolt technology and approach but it is a departure from USB and FireWire as it is more a bus extension rather than peripheral interface, interesting stuff.
Simon
In theory a cinema display with thunderbolt can host Ethernet, esata, hd video and thunderbolt HDDs at very fast speeds.
Job done
Tog
