New Software Update for NDX
Posted by: Asenna04 on 01 February 2012
Has anyone done the following software update announced on 19th Jan 2012? What are the improvements?
https://forums.naimaudio.com/di...nt/13111295372708974
Posted on: 01 February 2012 by roo
It doesn't restart the streaming interface quite as often when you play FLAC files from uPnP or USB. I also find that iRadio doesn't restart quite as often.
Posted on: 01 February 2012 by Jack
It fixes the buffering problem with high resoluion FLAC files  which caused interuptions
Posted on: 01 February 2012 by Simon-in-Suffolk
Hi. it provides art to web radio, it fixes some bugs with web radio URLs,  it addresses the hires album art in file stability issue, it provides progress update info to the NStream controller, it fixes some codec & bandwidth  reporting errors in web radio amongst other things
Posted on: 04 February 2012 by kiba
Is this allso for Unitiserver ?
