Is the NDX support the AIFF up to 24/192 after upgrade the broad ?
Posted by: marcobb on 06 February 2012
Is the NDX support the AIFF up to 24/192 after upgrade the broad ![]()
I have one album aiff 24/96 but not work, any comment ![]()
marcobb
From the product page:
| Audio Formats Supported | Internet radio (Windows Media-formatted content, MP3 streams, MMS), Playlists (M3U, PLS), MP3, AAC (up to 320kbit/s, CBR/VBR) Apple Lossless (from iPod), Windows Media-formatted content-9 (up to 320kbit/s), WAV and FLAC (up to 24bit/96kHz via UPnP or USB |
Is it same as after upgrade the streaming board ?
Why would supported formats be different?
Because the upgraded version streams up to 192/24 - at least for FLAC format.
Sample frequency has nothing to do with format.
The support of 192 kHz is in this case a hardware issue.
SUpported file format is only a matter of software.
So a change of hardware to support 192 kHz is unrelated to file formats
Hi Marcobb
A few weeks ago, I emailed Naim to ask if I could stream AIFF files from a NAS drive to a Naim streamer or UQ:
The reply was:
"... all our new units including Qute (you need to specify the 192kHz/ALAC/AIFF version when ordering) can Stream ALAC/AIFF so your problem is solved, you can then use one folder and all your Apple products will see the music."
Hence, so long as you buy/have the 192kHz/ALAC/AIFF version, you can can rip or download to the NAS in AIFF format, then stream them to Naim devices and Apple macs & mobile devices happily from one, common shared music folder.
Does this answer your question?
Best regards, FT
Hi Marcobb
The reply was:
Best regards, FT
Hi FT,
Thanks for your information.
I know how to stream the song to the NDX but it display "Can't Play" when i stream that.
I already upgraded the streaming broad and the software version to 3.9.
I will send email to naim support to enquiry this issue.
Thanks,
marcobb
Hi Aleg,
As asked naim support, they also said the NDX support below format after upgrade the broad and software.
Audio Formats Supported WAV, AIFF and FLAC (up to 24bit/192kHz ) ALAC (up to 24bit/96kHz) Ogg Vorbis (up to 320bit/s) Windows Media-formatted content-9 (up to 320kbit/s) Playlists (M3U, PLS) MP3, M4a (up to 320kbit/s)
Anyway, wait them reply my problem.
marcobb
Dear All,
I confirmed the NDX is support the AIFF up to 24/192 after upgrade the streaming board , it is my file issue and still investigate, thanks naim support to help me verify it.
Thanks,
marcobb
On a similar note -
I have just got my NDX back with the new boards.
The NDC app for the unitiserv still shows in "music library" my FLAC files - however, the streamer can not see them.
Based on comments above they should still work.
Has anyone else had this problem?
Andrew
Please ignore - I resolved it - was a settings issue.
Andrew
Dear Marcobb
How did you solve your m4a (24/192) problem because have the same on both upnp and usb fron port on my NDX
if file covert in Wav it's ok but not on m4a format.
Tks for your tips
Phil
Dear Marcobb
Tks for your tips
Phil
Hi Phil,
M4a (up to 320kbit/s) only.
marcobb![]()
TKS...made a big mistake by Mixing the extension (.xxx) and the Quality.
so :
- M4a till 320
- Wav till 24/192
Made a conversion of some of my m4a 192 to Wav 192 => just perfect (both Upnp and USB) ![]()
So the point will be how to add 192 track on iTunes..without having them translate by itune in m4a ![]()
Tks a lot.
