Has anyone had this with their nVi?
Posted by: Consciousmess on 07 February 2012
Hi all,
Before I write this post, I must say that due to what the nVi is, it probably ranks as my favourite component, but something has been happening fairly recently and I want to know if anyone else experiences this.  I would like to also say that I recently got the nVi back from a full service after being concerned about the delay and not locking on to the signal.
Anyway, sometimes right now the nVi shows that it's locked on to e.g. the Sky HD signal, but no sound comes out and this is in 5.1.  Funnily enough when I put it in mono, the sound comes out of the centre speaker!
Does anyone know what's going on?  It doesn't happen all the time, just sometimes.  My other equipment is NAP250.2; nDAC; Blu Ray player; 282; nSATs et al. speakers.
Many thanks,
Jon
Posted on: 07 February 2012 by Consciousmess
Incidentally, I have put a T-shirt on, so I will update my photo later ------ don't like to offend the sensitive ones amongst you!!!!!!!!
Jon
(I may get hot with my T-shirt in the sun, so we'll see how this goes.............)
Posted on: 10 February 2012 by Richard Dane
Nice T shirt Jon.  anyway, I just wanted to say I've flagged this for tech input from HQ.
Posted on: 10 February 2012 by Phil Harris
I've flagged it up for our n-Vi guru to take a look at when he has the chance but can I reiterate that support queries are much better routed to "support@naimaudio.com" and put through that way...
Phil
Posted on: 11 February 2012 by Consciousmess
Thanks for that Richard and Phil!
Jon
Posted on: 15 February 2012 by Phil Harris
Can you drop me an email directly at phil.harris@naimnet.com ?
I need to know what software versions you are running on your unit and also the serial number.
The software version can be obtained by pressing and holding PROG button on remote control for 5 seconds. Front panel will display one of the below sets of strings for latest firmware. (See below for information on the two firmware releases)
PIC c02-15
CHEERS 000.189.005.006
OR
PIC c02-16
CHEERS 000.189.005.003
NOTE: If the n-Vi has the latest display fitted the software will be
PIC c02-21
OR
PIC c02-22
Firmware status:- Last updated 27 October 2008 (available as disc based update via your dealer)
Important information concerning n-Vi code versions: 0.189.5.6/DVc02-15 and c02-21/189.005.006 also 0.189.5.3/DVc02-16 and c02-22/189.005.003
To accomodate for a material dependant variance concerning SPDIF latency, Naim have released two versions of n-Vi code. As per 27th October 2008, new builds of n-Vi will be delivered running 0.189.5.6/DVc02-15 code. This has, amongst other things, fixes for lip-sync/latency issues at the expense of longer SPDIF lock-on times (material dependant).
We would recommend using the current production code if you are an avid movie fan, but if you are mainly watching SKY and regular TV and are experiencing problems the longer SPDIF lock-on times, then we would suggest you speak with your dealer, who can supply you with 0.189.5.3/DVc02-16 and DVc2-22. Note:- this has relatively fast SPDIF lock on times, but increased system latency which could at times contribute to lipsync problems.
Phil
Posted on: 21 February 2012 by Phil Harris
Don't seem to have had an email on this yet Jon?
Phil
Posted on: 22 February 2012 by Consciousmess
Thanks Phil, I have emailed you.
Jon
Posted on: 27 February 2012 by Phil Harris
Not had any email on this Jon - what address did you email?
Phil
