horrible sound out of AV input when nothing is connected
Posted by: Hififriend on 07 February 2012
Hello
On my Nac 282 after I tried X-Box on Aux2 with Chinch (holded program button and pushed 6) and it worked perfectly, then I tried Ipot touch with original Mac cable and there got no music out (perhaps it's normal), it worked on a Cambridge Audio A500 !?
Then I pulled out Headline connected to a 2nd Napcs (on Tape input) and I pulled out Phono (Rega P3 by Chinch). I did all this to reduce cables because I had sound problems....long story :-)
So by chance yesterday I switched through all the inputs (a KT 1100 is now connected at Aux2 by Chinch).
and AV (without anything connected at the AV input) there is an awful loud noise coming out of the 2 speakers.
When I hold "prog button pushed" it disappears but comes back.
I never heard such an awful noise
Please help.
There is nothing connected on AV2 !
thanks
hififriend
Posted on: 07 February 2012 by Hififriend
hello
ok I found out-Unity Gain programmation by remote control
I did not read the general information about the preamps.
They could have made a note after the specific explanations about the Nac 282 in the manual.
not well done.
no need to bother.
thx
hf
