Coaxial or Optical SP/DIF
Posted by: djh1697 on 07 February 2012
Has anyone done a comparison ? I appreciate that there might be "clean earth" issues, however, I am in the process of acquiring an ITX motherboard and just wondered if there are actually any difference in quality?
Posted on: 08 February 2012 by hego99
There are probably numerous threads here (and elsewhere) comparing the pros/cons of the two types of cables. Also note that coaxial uses two kinds of connectors (RCA or BNC).
I'm no expert (on digital audio), but one thing to consider is the quality of the "implementation" behind the input/output connectors, on both source/transport and DAC.
For example, it is said that older Macs had relatively high jitter on their toslink-out, but the 2011 version of MacMini has a better (lower jitter) toslink-out.
In a recent thread here (I can't find it now) someone compared Coaxial and Optical into a NaimDAC claiming that Coax sounded better, which may point to that Naim has put more effort in the Coax-inputs than optical on the nDac.
But this may of course  vary between different DAC-products.
Posted on: 08 February 2012 by NickSeattle
Some people even hear differences between cables of the same type. I know I do.  It probably shouldn't surprise a Naim owner that execution of anything can impact sound quality.  I do not know if it is settled that well-made co-ax beats similarly well executed optical.  The things you are connecting play a role, too.
One question I have about optical is whether or not, over time, the end points accumulate dirt or film that would degrade performance?  Metal connectors can be refreshed by unplugging and re-plugging.  What can one do to maintain optical connections?
Nick
Posted on: 08 February 2012 by Noogle
The Toslink plug sits within the socket which keeps the dirt out.  You could always polish the end ot the plug with a cloth soaked in alcohol if you are worried.  I've never heard of a Toslink connection failing to work because of dirt ingress.
Posted on: 08 February 2012 by meissmar
I have also done the comparison between toslink and coax in my environment. source components were a SAT from Topfield, DVD player from Denon etc. I have compared the sound from a CDX2 with Dig-out (BNC) into the nDac when connecting others with Coax. To be clear: I only connected others with Coax, and listened to the CDX2 before and after. Everytime I heard that the CD-player sounded worse. So I agreed with Naim saying that toslink should be preferred for other source components.
Regarding Toslink vs. Coax, this must be heard for each source individually. There is no rule which will be better. It is always a function of every component involved and the effect this has.
Mario
This is from the FAQ at the end of the nDAC White Paper:
• Why S/PDIF optical rather than coaxial?
Coax can sound better but optical has the advantage
that it prevents ground loops and isolates the ground
system of the source, which may be noisy, from that of
the Naim DAC.
Posted on: 08 February 2012 by Zinger
My friends and I have done a comparison on the nDAC: A. BDP > Benchmark DAC via Toslink B. BDP > Benchmark DAC via BNC C. BDP > nDAC via Toslink D. BDP > nDAC via BNC E. AppleTV > nDAC via Toslink F. AppleTV > nDAC via BNC Note that scenario F was modified AppleTV with BNC output. This thread isn't about how that's done as I don't wanna get myself or anyone else in trouble. Lets just take my word that it is there and leave it as is. The test was done via a 202/200/NAPSC.2/HiCap.2 setup with all the equipment around 2 to 3 years old. Same music CDs were used in the test for A to D; the songs played via iTunes/AppleTV in E & F were ripped via Apple lossless format. // Test #1 We started off with A & B to make sure that the BDP had no bias to either of the outputs, and that the Optical cable was up to par. The result was that there were no major differences noticed. // Test #2 B & C comparison was meant to test whether Naim DAC's Toslink and BNC input had any differences in sound quality. In a blind test between 3 of us, all concluded that the naim DAC with BNC "sounded" better in a variety of music. The BNC input provided a more lively effect, while on the Toslink everything sounded as if the instruments are on the floor or vocals were somewhat muffled in comparison. At the same time the sound coming through Toslink sounded as if the equalizers were such that the highs and the lows somewhat "overboosted". The BNC input sounded closer to the CDx2 than Toslink did. //Test #3 This E & F were a final test done to see whether it the same on a different source and in a streaming environment. The result was the same. Another friend conducted his own test independently via his Mac Mini into NDX/555PS (using the internal DAC) vs Benchmark DAC Through 252/300, and he also had the same conclusion. I have tried repeating a similar test on the XS/FlatCap/nDAC but didn't notice a big difference at all. Just sharing my experience here
Posted on: 08 February 2012 by Phil Harris
One big difference between the two is that *GENERALLY* TOSLink (optical) transcievers won't go up to 24/192 and top out at 24/96 (for a reliable link) whereas electrical is stable to 192...
Phil
Posted on: 08 February 2012 by rich46
again,  if you purchare a good quality opto cable that  is perfectly toshed the difference are so small,.in a noise enviroment opto is best. personal i prefer cable. some really classy opto cables out there now
Posted on: 09 February 2012 by Simon-in-Suffolk
Though I notice many *quality* TOSLink transceivers are often specified around 15~16Mbps which should be more than good enough for 192/24 which is around 12.5Mbps
Posted on: 10 February 2012 by Bob Shedlock
I believe  it was Hi-Fi world that tested the jitter of a 2011 model Mac Mini  optical output and found it's output to be in the area of 15ps, which is quite low. As I recall, the signal to noise was quite good too. Those numbers are substantially lower than the previous mac's optical output, indicating to me at least, that Apple have done something rather dramatic to the newer minis. I have also read on other forums that the 2011 mini does not support integer output on USB any longer. However, when working with the "midi" settings on my Mac, it indicates 24 bit integer output, although I have no way of verifying if it actually is.
The n-dac seems pretty impervious to differing inputs since once it grabs the incoming signal, it does what it does internally almost in a closed loop fashion. But to the OP's question - I have listened at length to the n-dac using a glass fiber optical connection and a Hallide Bridge usb to spdif hardwire. Both of them are very good and the hardwire doesn't exhibit more noise or grunge than the optical connection. There absolutely are differences though. They are small. In audio people sometimes spend big money on small differences. The optical connection presents with more layering in the soundfield, and that presentation is broader. The hardwire is a bit more upfront and maybe, just maybe, has somewhat deeper bass. It is elusive.  Timbrally, they are equal. Sometimes it seems like the hardwire has a bit more sibilance on female vocals. I find it difficult to make up my mind which I prefer. They're pretty darn good, both of them, and the differences are subtle enough to be merely  "different". If it was just about the cost, I'd go with the optical since it is much less money than the hardwire. That is my experience in my system. Listening for months now and no clear winner.
Posted on: 10 February 2012 by Clay Bingham
Bob
Your name seems familiar. Did you write for Art Dudley's "Listener Magazine"? It was a great read.
Posted on: 11 February 2012 by Bob Shedlock
Your memory serves you well. I hope you enjoyed my articles as well. What strikes me most about audio from then to now is how the toslink protocol has evolved. Back then it was the lowest form of connection in the digital hierarchy, with demonstrably inferior quality. Apparently opti-couplers and interconnects are now contenders. At least those implemented in the n-dac and Apple products.
