DTC crashes on Windows 7 pro, works fine on xp.
Posted by: Claus-Thoegersen on 19 February 2012
This should probably be a support question, but it would be interesting to see if I am the only one having this problem.
When I start the Desktop client on my Windows 7 pro 32 bit machine, I always get the following error about 20 to 40 seconds after I start the program:
Attempted to read or write protected memory. This is often an indication that other memory is corrupt.
After searching for the error on the net, it seems that it is one of these MS error messages that occurs with no good reason, or at least no good explanation and solllutions from Microsoft.
For a long time I thought that I had ram problems on the machine, but I doubt it, since everythihng else works okay, and afterthe first crash the DTC works fine until I start it next time.
Claus
Posted on: 19 February 2012 by sktn77a
I'm using Windows 7 Pro SP1 32bit.  No problems whatsoever with the latest version of DTC.
