nStream - FLAC format tracks displayed in wrong order
Posted by: Peter W on 19 February 2012
My nStream displays FLAC tracks in alphabetical order instead of the original order in the album.
I use QNAP 219 pro II with the pre-installed Twonky server.
Tracks are ripped like this: [album artist]\[album name]\[track number] - [track title]
With WAV files, nStream displays properly according to track number, showing:
01 - Catherine
02 - Alex
03 - Brian
but with FLAC files the numerical prefixes (track numbers) are gone, becoming:
Alex
Brian
Catherine
I tried to search old posts but have found nothing too useful. Is there anyway I can have the tracks displayed in the correct order?
Many thanks.
Posted on: 19 February 2012 by Peter W
I forgot to mention that I have this problem when I am searching "by folder". If I search "by album" then the track order is fine. However I prefer "by folder" because I already have hundreds of CDs ripped in WAV format which cannot be found "by album".
Posted on: 19 February 2012 by PinkHamster
Take a look at yout metadata. I guess that the track name has been taken over but the track number have not. The sorting is no longer performed along the folder/file structure but n-stream will now look at the tags where they are available.
Thanks for reminding me to check the metadata. The track number prefixes were not in the metadata. I manually added the track numbers and the orders are fine now! OK, it is a bit tedious to add track numbers manually, but at least this is a good solution for now.
Posted on: 20 February 2012 by winkyincanada
Originally Posted by Peter W:
it is a bit tedious to add track numbers manually....
I'll say.
