Which playback software do you recommend?
Posted by: novak on 04 March 2012
Happy Sunday, folks!
I have just been looking into various forms of 'audiophile' playback software for Mac.
I use a 2011 Mac Mini, Wireworld Supernova Cable into a Naim Dac, onto a Supernait. I currently play tracks through Enqueue, which is easy to use. My files are FLAC.
I have read up on Amarra, Fidelia and others, but I'm just not clear on whether these offer any improvements?
What are your recommendations and thoughts on the best software to use?
I used to use itunes in to my nDAC (I also have a SN) via an optical cable. It was always poor in comparison to the USB sticks. I tried Amarra etc but found the difference negligible and the hassle of messing with them painful.
Running apple lossless off my ipod classic sounded better. I'm using spotify premium off my ipad and I'm pretty sure that sounds better than my Apple portable via optical - but it has been a while.
I now have an NDX in to the nDAC and it really does sound a lot better than my Macbook did.
I'm yet to be convinced you can get a good sound from a PC or Mac (unless you spend as much as you would on a Naim Streamer with someone like Item).
Huw
Enqueue looks OK. Nice and simple.
A couple of things I look out for in a player -
Does it automatically switch sample rates?
Will it convert file formats?
Does it have a Remote app?
I agree there's really not much difference between the various types of playback software for the Mac but it's worth trying a few; most offer a free evaluation period.
I finally settled on BitPerfect. Only a few quid, works perfectly in the background and unlike iTunes it'll automatically switch sample rates.
James,
All the above provided by Fidelia. Are you still using it?
Guido,
It's also i-Tunes friendly and can convert to many file formats including FLAC.
Novac,
There's also a free trial period.
Graham,
Yes, still using Fidelia.
However I have a USB to S/PDIF adaptor on the way as I feel the (current) optical connection has a flavour/character all of it's own (which changes depending on the cable used) which makes everything sound 'same-y'.
Will advise how the new hook-up goes!
VLC is worth a try as its free and plays FLAC.
Graham,
I understand from your "Homogenised" post you're getting a Halide Bridge. I'll be interested in how you find it compared to optical. There seem to be many opposing views on the Forum.
Which post will you advise us on? This post or the above?
Other than CD what is your digital source?
Hi Novak,
as you already have your music files in FLAC format, you may want to take a look at Audirvana. It works either as a standalone player or a front-end for iTunes. It also allows for non-iTunes formats, like FLAC, to be played & cataloged from iTunes so you may find it useful for handling your FLAC library.
I've been using it for a few months now & I really like it. It can also be controlled from the free Apple Remote app. There's a free 15-day trial so I'd recommend you giving it a go.
Matthew
Sorry about the stupid question, but what's wrong with itunes?
For the mac (and PC it appears) I would suggest you try songbird. Free and good.
No flac
No secure ripping
No auto sample rate switching
No easy converting (is there)
No wav tagging
No upnp
No multi-zone music (unless you want to hear the same thing everywhere)
Just to name a few of 100s of possible shortcomings.
-Patrick
A brilliant $5 app called BitPerfect does this without any fuss. It is a stellar app. Runs completely in the background but does auto switching of bit depth and sample rate. It also allows the allocation of high priority of processing power to the media player by the OS. I can't recommend it highly enough.
But as Patrick points out, iTunes just plays a single stream of music. Doesn't do anything flash. Lack of native FLAC support is a weakness. I just convert those few FLACs I end up with.
Bit Perfect fails to play my Apple-DRM'd music. I only have five such tracks. I have given up on them and bought the CDs! All is well.
To answer OP, I use iTunes (with and without BitPerfect and PureMusic) and SBT. I am about to load JRMC on my project-PC and give it a whirl. Some of you may not have heard of it; a friend of mine says it is rather special.
Nick
No it doesn't actually. Perfect is a VERY strong word. Not ripping hidden tracks and pre-gap data is just one glaring oversight. There are others but this is one that everyone can hear. Where was that lead in Miles played? Where is the crowd at the beginning of that live Ray Charles? Pre-gap may be rare, but perfection has a fairly strict definition. Sorry.
-Patrick
Your friend is wise.
Sensible posts from Mr Fawkes. If you've a Mac, iTunes makes sense and is fine. If you're wanting automatic bit-rate switching then BitPerfect's the best choice because it runs perfectly happily in the background and is dirt cheap.
Patrick, please excuse me for maybe getting misled, but having studied your postings I do get a slight sense that you're not 100% sold on iTunes? Forgive me if I've read this wrong.
Tony,
I don't know what has happened but I cant't get V1 of BP to work.
If I had a Mac, and a Mac only, I would use XLD and iTunes. There aren't many other decent choices that I know of.
That said, if either platform had something serious to offer me I would buy one as my dedicated audio computer without prejudice.
I used iTunes for years (on a MB and a PC) until I was shown other far superior options. And I still use it daily to sync my iPhone with Outlook.
In the rare case you end up with a CD with Pre-emphasis (I have more than a few), iTunes comes in handy for burning a de-emphasized CD, that you can then rip properly in EAC ![]()
-Patrick
Interesting to read up on these, and thanks for the input.
So far I have tried:
iTunes (nice interface but no flac)
Songbird (seemed to be full of bugs)
PureMusic (attaches to iTunes, so same applies)
Enqueue (Nice use interface and seems to sound good)
Amarra (Looks awful, can't do libraries unless you use iTunes - and expensive too)
My choice is: Fidelia.
There's not much between this and Enqueue, but I think it might be a little more refined in SQ, but it's only very subtle if it is. The interface looks to be stable and haven't had any problems so far.
I like Fidelia.
One thing it doesn't do is you can't start playing a track by highlighting the selected track and start the song with the space bar. The only way, as far as I can see, to start a track is to double-click. A tad annoying.
In comparision to iTunes, I don't get ear fatigue with Fidelia.
iTunes has always sounded "bitty" to me.
