CD Ripping Software
Posted by: Daunt on 09 March 2012
Being a Mac user and a relative newcomer to quality audio streaming I am wondering what ripping software other Naim and Mac owners out there use?
I am currently using a last generation Iomega Stor Centre Raid for my music (which I intend to replace when funds allow). Unfortunately the uPnp firmware on this doesn't seem to be passing the AIFF formatted files I use onto my Uniti which just doesn't see the files or the file structure. At best it sees the odd file and says it is in 'unknown' which isn't a lot of use really.
Once I convert the AIFF files to Flac (using switch for Mac) everything is fine, but I don't like adding another layer of processing to the files. Has anyone out there had experience of this and found a solution or workaround? I am right in presuming that drives on the Naim 'approved' list would enable AIFF files to be correctly displayed on the Uniti?
I am about to experiment with Rip and Max from sbooth.org, which seem to be offering the quality ripping necessary for good streaming - anyone out there dabbled with these applications?
I am also intending to record a selection of my beloved vinyl using Sound Forge (which works for me) and a couple of excellent plugins, but this programme runs in windows so, again, I am wondering what other mac users out there are using to rip their vinyl?
