iTunes 10.6 Scrolling Bug
Posted by: J.N. on 19 March 2012
In my music library, clicking to scroll up or down doesn't work. I can drag the scroll bar, and the mouse wheel scrolls the list, but a click above or below the scroll icon doesn't work, as it used to.
Weirdly; it does work if 'Store' is selected.
I gather it's a known bug with v 10.6.
John.
Posted on: 20 March 2012 by GML
Strange isn't it. I'm not experiencing any scrolling problems with 10.6
Posted on: 20 March 2012 by tonym
Yes, I noticed that too John. A bit irritating when you've a large music collection to go through. I also don't like the fact that the vertical scroll bar disappears when you're not using it & you've got to click on where it's supposed to be before you can use it again. I think this was the same in the previous version.
Posted on: 20 March 2012 by BigH47
I can't say I've noticed any changes (10.6.40).
Posted on: 20 March 2012 by J.N.
It appears to be a known 'issue'/bug with v 10.6
https://discussions.apple.com/...start=0&tstart=0
Dependent upon one's chosen layout perhaps?
John.
Posted on: 21 March 2012 by madasafish
There was a problem with itunes crashing after the upgrade to 10.6 (including me and 1000s of others when I 'searched' on the problem). Others were completely unaffected and I don't think Apple yet know why.
I had to dump 10.6 and re-load 10.5.3 - kerfuffle.
Posted on: 21 March 2012 by GML
An issue affecting those using Lion? All is fine with Snow Leopard.
I suspected the opposite - I still use Snow Leopard. Very odd.
