Readynas too noisy for use in my livingroom?
Posted by: Claus-Thoegersen on 21 March 2012
I need a nas to store my downloads, and to make a second backup for my ns01. I am spending too much time comparing all the different nas versions and brands I can find. I do not really need all the fancy extra services any new nas has, but I need a quiet nas, since it has to be placed in the room with the rest of the hifi.
I can get a cheap readynas duo 2110. It is on the list of Naim tested nas, the only problem is that many users report that the fan noise is hard to live with, so a common tweak is to replace the fan installed in the Readynas. I do not want to buy a new unit and start by either destroying it in the process of changing the fan, or to have a very noisy unit.
Another cheap and quiet sollution is to get a Western Digital My Book Live nas. I am aware about all the limitations it has. The only problem is can it work with the Naim servers? It is not on the old list of tested units, and some users on the net reports a lot of problems when used in other streaming setups.
Reading on the net it seems that the Synology 211 or 212plus models have very quiet fans, and some qnap models also, but this comes at a higher cost than the Readynass duo.
Claus
