Does anybody know how to move music between "music stores" with Naim Desktop Client for Naim servers? There is a "Move Album Monitor", but there seems no way to initiate the process in NDC. The control seems to be only on the display or web interfaces. Am I missing something? Moreover, you can not select a genre, or a composer, or any subgroup to be moved; you can select either all albums or single albums!
Posted on: 25 March 2012 by GerryMcg
Hi Aysil,
Not sure I filly understand your issue. But yes you cannot move music between stores using the DTC but it is a function of the web browser. You can move albums between genres with both the browser and the DTC. I do not understand why you would want to move composers between stores, this would, if allowed, break the album based structure of the store.
Cheers gerry
Posted on: 26 March 2012 by JohnBooth
Go to: Tools Tab>Music Repositories>Stores for ripped Music.
Highlight the store you want to move music from; the albums on that store will show in the right hand frame.
Select the albums you want to move and drag them to the required store in the left hand frame.
