Do you use your NAS just for music?
Posted by: Renzo on 22 April 2012
Hello, I'm just about to decide on my new NAS for my music files. Having a photo library that would be useful to also have on the NAS I was wondering if there are any pro's for just having the music on one NAS and all other files on a seperate one, or can I just go ahead and put them all on the same one? Thanks
Hi, my NAS is used for many things, my photos, some types of backup as well as audio, but i run a seperate uPNP server from my NAS.
Simon
Photo library streamed to iPad or Sony PS3 works great. Also use it for streaming films (DVD and MKV rips of Blu-Ray) direct to PS3.
Yes - I use the Vortexbox for music only - no reason it couldn't serve photographs using a share to iPhoto or similar, but not something I've ever tried.
Geejay,
Can I ask what you are using to streamphotos to your iPad? What software on the iPad?
Renzo
I only got my Qnap NAS a couple of weeks ago. I got it purely to go with my Unitiserve SSD. The only thing that I use the NAS for, is to play back music. Of course though, you can use the NAS to store anything you want, providing that the file types are supported.
Geejay,
Hi David,
There are a range of Synology apps (I have the Synology DS212 NAS) available from the App Store, and the one for photos is called DSPhoto +. This app allows you to directly look at the thumbnails of your photos, perform a slide show and even edit them in iPhoto (or other photo editing apps). I'm sure QNAP and the other manufacturers of NASs have similar apps available. Just do a search on the App Store for whoever makes your NAS.
One of the other Synology apps (DSAudio) allows you to stream music files directly from the NAS to UPnP devices (e.g. Apple TV, Sony PS3, Pioneer A/V system, NDX and even to the iPad itself), transcoding as it does so.
Hope this is helpful.
George.
Use my nas mainly for serving music, storing pictures and videos/DVDs, and as a time machine backup for my mac.
Same here with the Vortex box, Music only.
The Mac does photos,but then i burn them to discs after a month or two.
I need things keep things simple.
Stu.
Had a QNAP a couple of weeks and only use it for streaming music. However, when I have a bit of time I will be attempting to use it as a print server.
Thanks for the replies guys. I keep my photo's on my PC at the moment running Win 7 and using Elements. My daughter has a Macbook and keeps her's in there. I was wanting to keep everything centralised on a NAS. My main concern was whether the streaming performance would be compromised if the NAS was being accessed simultaneously for music and photo/video work?
Here in Rio I also stream video, but never at same time as music. Saved having to haul my DVDs all the way down here. Back in uk in couple of weeks, and my new system in uk coming together. Want a NAS to support the hi-res files I have to use with my HDX. Torn between a faster NAS (qnap ts-259pro+) with a 2 tb HDD, or a slower NAS (qnap ts-219, or even ts212) with a 480gb SSD. Both options fit the budget. NAS will be dedicated to music. Storage volume isn't a huge issue, as mainly only for hi-res stuff so the ssd will be large enough as have the ability to add 2nd later. Any opinions would be appreciated.
My NAS is actually a WHS2011 server with 3x2Tb drives running RAID5 with an effective 4Tb protected storage. I use it for music, images, backing up my iFleet and misc general file storage, letters etc..,
Cheers, Julian
Did you build this yourself, Julian? Thanks!
Hi
Its a HP Proliant Microserver which comes as a basic unit with no O/S and a starter hard drive. I used the starter harddrive for the O/S and added the three 2Tb drives, increased the RAM and installed WHS2011 and Asset uPnP on it.
Julian
Hi
Its a HP Proliant Microserver which comes as a basic unit with no O/S and a starter hard drive. I used the starter harddrive for the O/S and added the three 2Tb drives, increased the RAM and installed ....
Julian
Sounds an ideal candidate for a Vortexbox ![]()
Hi
Julian
I am not sure what adding that would offer over what I already have?
Hi
Julian
Nothing at all Julian ,,,, I just thought it sounded a nice server to use for running a Vortexbox.
In case anybody was thinking what's a nice server to run a VB on ![]()
All the best, Guy
That is the strangest use of the word upgraded I've ever heard -
Assuming Asset becomes available on Linux or OS X what would its advantage be to me?
The Vortexbox works perfectly and serves UPnP streams to my Naim UQ.
I'm really puzzled what a different server could do that I would ever use.
Other than transcode to WAV on the fly, which is interesting - does Asset do anything extra that another UPnP server cannot?
Hi - I use my NAS for music, video and photos. Separate uPnp server on the NAS for music. Having it all in one place means I can stream music to my audio streamer, and also stream video and photos to my PS3 Also makes backup strategy very simple - USB HDD connected to the NAS. No problems at all.
Yes. It obviously does not require you to dedicate a computer solely to Vortebox duties.
Does a Vortebox do anything a nice NAS cannot?
Hi Guido
You can probably find the answer on the website - www.dbpoweramp.com. Here are my thoughts:
VB's UPnP app lets you pick a source folder and lets you choose to stream either FLAC or MP3 files using a limited (unconfigurable) browse tree. If you're happy with that then that's great.
Asset UPnP lets you pick multiple source folders (not just one) and lets you choose to stream a wide range of audio formats (not limited to FLAC/MP3) using a customisable browse tree. It also lets you apply filters, transcode, apply replaygain, handle "The", configure how to display tracks from albums with multiple disks, configure how to display track names. Basically it is a lot more configurable than the VB app, which I used for many months before my recent upgrade.
I've also used the app supplied with the Netgear ReadyNAS Duo, which is awful, and Twonky (on same ReadyNAS Duo), which is better than the supplied app but has some limitations. The VortexBox software is simple but does the job, and I used it for many months from when I ditched the noisy ReadyNAS Duo for the MicroServer until a couple of months ago. Since the end of 2010, however, I've also run Asset on my PC, which is turned off most of the time, and had a strong preference for it. I jumped ship as soon as I heard about the WHS2011 version of Asset.
Ian
