How can you set the display on the nVi so it is always on?
Posted by: Consciousmess on 22 April 2012
Hi all,
This question nags at me as I often have to select the correct source and necessary settings, can anyone help???
Jon
Posted on: 28 April 2012 by james n
I think the display off feature is hard coded to stop issues with the original display and goes off automatically after 2 mins of inactivity.
James
Posted on: 28 April 2012 by Consciousmess
Ok thanks James Jon
