SuperUniti and iradio problem
Posted by: keano on 26 April 2012
I got a weird problem and is confused. It started yesterday with that I would listen to the radio and turned on my SuperUniti. I have stored some channels and listened to one of these, but would then hear a second canal, and then just stood there "connecting" in the display and after a while "no station found". This is happening everytime i want to hear another stored channel. I can swicth off the SuperUniti and when i switch it on the channel is back on
I've tried wireless and with ethernet cable and there is the same. Have also tried with another Ethernet cable.
I have a Netgear cg 3000 Router that runs 20/2 mbit.
Hope you understand and can help
Posted on: 27 April 2012 by keano
It is ok today
Posted on: 25 August 2013 by 4411
Hi
Had a similar problem my stations become unselectable except for a couple which would come on but were slow to connect. I did a factory reboot and started the Internet radio off again thru nailms Internet radio web site and all is well now. Worst part is putting your fab stations back into your presets, write down your fa stations first.
4411
Posted on: 25 August 2013 by jobseeker
This thread is 18 months old !
