Do I need an Ethernet Switch?
Posted by: CDI on 27 April 2012
I have a Virgin Media Superhub Router wiich is fine and connects a SB Touch (toy before taking the plunge)to my Asset NAS 4TB server and will soon be connecting to either NDX or NDS.
My question is - why do I need an Ethernet Switch (Gigabit?) there are 4 ports in the back of the Virgin Superhub which can be used to connect everything I need
Sound quality is most important to me so will get a "switch" if I need too but would apreciate some help in understanding why I need one.
Thanks in advance
If there are enough sockets on the back, and your your devices can connect to it, you don't need a switch.
Switches are useful for increasing thenumber of sockets or you need a lot of sockets in a different room to the router so you would only need 1 cable between the rooms.
I'm far from convinced you'd get better sound from using a switch - if you wanted to use your system and disconnect your router then you could with a switch - I use a Juniper switch which is an industrial strength device and built like a tank, but I use it 'cos I have it and it is useful in my set-up for connectivity, not because it makes any difference in SQ.
When/if I get the NDS I'll use an Apple Extreme to do switching duties downstairs - I have no wired Ethernet down stairs so I'll create a little wired network behind the Fraim.
As said, if the switch ports are free on your Internet router, use those. However to cut down on lengths of patch lead, you might want to have a switch near several devices, and then one patch lead back to your router.
One little point, is that some 'bundled' Internet routers are actually quite poor at switches, and don't correctly support TCP/IP features like multicast (not used for simple web acess applications) but required for streaming. However assuming you have no problems your bundled router switch ports would therefore be working fine.
Simon
I seriously don't know what the Streaming Audio forum would do without the extreme knowledge and advice that comes from both Guido Fawkes and S.inS. I would really like to thank you both for your invaluable help to me and all forum members.
"invaluable [ɪnˈvæljʊəbəl]
Andrew - that was unexpexted - you are welcome - you make me feel all embarassed ![]()
I was under the impression that the speed of the router will determine the actual speed of any ensuing switch so regardless of using a switch that has Gigabit capability if you hang it on a Megabit router you will only get megabit connections out of the switch.
I wait to be corrected cause I may be wrong. ![]()
The big benefits of the switch is in creating more connections and the probably superior switching between ports since that's all it does compared with a router which has to handle WiFi, internet etc so typically has less quality in its switching circuits.
Geoff
Geoff, the switch is independent of the router. Therefore any traffic flowing in and out of theswitch is governed by the slowest link in going from A to B. if that path doesn't gp via your router then the router has no impact of the speed between A and B. That's the benefit of a switch over a hub. That is why switches are preferable to have near or connected to components transferring data between them selves. You can see therefore where a device is on your network can affect its performance.
Simon
A very kind comment - thank you.
