n-Stream updated again
Posted by: 0rangutan on 09 January 2011
Updated on App Store today - looks like it just adds iOS 3 support.
Posted on: 09 January 2011 by Tog
Minor bugs - more stuff for NDX is the real reason - slightly snappier
Keep going lads - just think Ipad ,,,,
Tog
Tog
Posted on: 10 January 2011 by ste71
Since I updated n-Stream to 1.4 on my iPhone 3GS, it seems I can't access my UnitiQute anymore. It is invisible. The wireless network should be OK since I can still control the UnitiServe with the iPhone.
My iPad, which is still on n-Stream 1.3, works fine with the Qute.
Any suggest?
Thanks.
Any suggest?
Thanks.
Posted on: 11 January 2011 by Phil Harris
Hi,
(Can I remind people that support requests are best routed by email directly to either me or Steve then we'll see them more quickly...)
The only change between 1.3 and 1.4 is that 1.3 was compiled without support for iOS 3.1.3 and that was added to 1.4 so there should be nothing changed on your 3GS.
Can you reboot your phone and run the app again from fresh rather than just exiting with the menu button and see if that resolves the issue?
Phil
Phil
Posted on: 11 January 2011 by Tog
Hi Phil - any news on the next big n-stream update aka iPad
Tog
Tog
Posted on: 11 January 2011 by ste71
Phil
After three reboots, the n-Stream app on the iPhone is working again.
I have the feeling it's now a little bit faster.
Thanks Phil.
