Small UPS recommendation ?
Posted by: james n on 16 January 2011
APC seems to be well regarded. Any advice would be welcome
James
Try a good surge protection fuse.
Tog
One reboot of the NAS, a reformat of the external USB drive and a new full backup of the NAS and all is fine again.
Having had one failed logic board in the Mac Mini due to power problems, i don't want to tempt fate so a UPS looks the way to go. A bit of googling has turned up this and for £60 its worth a punt.
James
I run a HP MediaSmart server, 2 x mac Mini's and an external e-sata box from the 4 battery bacup sockets with no problems. It also has 4 surge protected sockets too.
Shop about and you can get it cheaper than the RRP.
I have the ReadyNAS_NVX that is protected by an RS 800 UPS. This also supplies my modem, router and 24 port smart-switch; this gives 45mins run time when fully charged. The NAS is set to shutdown when the power reduces to 60%, which allows me well over an hours use of Internet using a laptop after the power fails. Well worth it to me.
Do remember to check the UPS compatibility list on the ReadyNAS website before purchase.
Peter
Peter - many thanks. Checked the compatability list and it'll work. APC it is.
Cheers folks
James
Whatever - you can't go wrong with APC, whichever model you go for. They are solid bits of kit, I've installed loads of units over the years.
i am also considering purchasing the APC Back-UPS RS LCD 550VA UPS for my ReadyNas Duo.
but noddy question; just noticed the outputs are IEC13, so did you guys remove the plugs that came with your router, NAS etc to connect to this UPS? or ?
enjoy
ken
Hi Ken
I think my unit came with one lead, which I used to supply the NAS. I then purchased a 1mtr 4 way 13A extension lead fitted with a IEC13 plug and used that to supply modem, router and switch.
Be aware that the IEC 13 plugs seem to come in 2 versions; by this I mean they are either square or chamfered on the front edge. You need the chamfered type, as the square whilst it fits does not lock into the socket making the connection insecure. The connection will be intermittent if the cable is moved, not a lot of good as you can imagine. The lead I bought is not available now, it cost about £7.50, which is very cheap compared to the leads sold by the UPS manufacturers.
Hope streaming is going well for you.
Peter
thanks Peter. Streaming is going quite well. just listening to the rips made so far. i am actually surprised they sound as good as they do given that i don't have a power supply on the nDAC!
in addition, something i find curious happened recently. when i was away on business, i asked my daughter to switch off the system because of an impending thunderstorm -- just as well, it was quite bad. when i came back and connected it up again, the system sounded a LOT better than i recall!? some kind of reset?
back to ups, i assume higher rating (800VA) keeps pumping juice for longer in case of mains power failure.
enjoy
ken
You are right about the sound Ken. I must admit I have to consciously remember to switch the power amp off from time to time, but to be honest, often It’s only off for 5-6 hrs overnight; it just stays on.
Yes, with the UPS its as you say, higher the power the longer it lasts. To give an idea my NAS has 4 discs and reports autonomy of 45mins. I have set the ReadyNAS to shutdown after 60% of battery use as my Modem, Router and Switch are also connected, the 45mins assumes only the NAS is connected of course.
I must say that it is quite reassuring having a UPS on the NAS.
Peter
sorry to hijack thread, but hopefully this question is of general interest anyhow.
anyone using Seagate the "2TB FreeAgent GoFlex Desktop Hard Drive - USB2.0 - STAC2000200" as backup drive on their NAS (specifically NetGear ReadyNAS Duo) care to share experiences, setup, issues etc etc. Many thanks
enjoy
ken
