Recommend any good 320kbps internet radio stations?
Posted by: Shinyroundbauble on 13 January 2011
Hi,
At the moment, I listen to Avro and Linn's 320kbps stations.
Does any one know of any others out there on the interweb?
Thanks in advance!
Posted on: 13 January 2011 by Blueknowz
Radio Paradise
Posted on: 13 January 2011 by daryl
Radio Paradise is good,but i only 192kbps.
Posted on: 13 January 2011 by BigH47
RP @ 128 AAC sound pretty good to me.
Posted on: 14 January 2011 by badlyread
Have to agree with the above - it sounds damn good!!
Posted on: 14 January 2011 by Analogue Rules OK
BBC are bringing out hi-def soon 320kps
Chris N
Posted on: 14 January 2011 by likesmusic
Radio 3 is already broadcast at 320kbps online. Do a google on BBC Radio 3 HD - or try this. Needs a bit of wizardry, or a Logitech Squeezebox, to get it to your DAC.
Posted on: 24 January 2011 by Shinyroundbauble
Thanks everyone!
Posted on: 25 January 2011 by TJ
You could have a look at the vTuner website, choose a location then sort by "Fastest Speed". You can then pick the 320k streams from the list. Most of the audio streams on this website are available on the Uniti and Uniti Qute.
E.g. in the UK there are DeepVibes and Only Oldskool available at 320k (if that is your kind of thing thing!)
Posted on: 26 January 2011 by Joe Littlewood
Slightly off topic, but is there a significant difference in playback quality on an Ipod or MPĀ£ player bertween 320 and lossless ripping?
