Code to program another remote control to operate a DVD5
Posted by: Avalin on 29 April 2006
Can anyone tell me the 4 digit code that controls a Naim DVD5. I want to eliminate another remote control (ie the Naim DVD remote in addition to the Naim Narcom, Sky, and TV). My Sony TV remote will control the TV,DVD & VCR but unsurprisingly their handbook does not list the code for a Naim DVD player!!
Thanks in anticipation
Geoff
Posted on: 29 April 2006 by David Dever
From remote manufacturer to manufacturer, these four-digit codes vary–try (if available) the codeset for Arcam or Linn (who also use Philips RC5 codes).
Posted on: 24 May 2006 by AndyMac
If you email naim, they will send a PDF with the codes on.
Andy
