Craig Sheppard Plays Beethoven
Posted by: Todd A on 13 March 2006
Over the past several months I’ve read some positive reviews and comments about Craig Sheppard’s Beethoven cycle, so I figured I should probably try it out at some point. When the opportunity arose to acquire the set in a most affordable fashion, well, there was no reason to not give it a listen. Sheppard is a name I’d only seen once or twice before reading about the Beethoven cycle, and then only when scouring ancient reviews in Gramophone. Mr Sheppard has been around for quite a while, it turns out. He placed second to Murray Perahia in the 1972 Leeds competition, and has made a variety of recordings of a reasonably wide-ranging repertoire on a number of labels. One of his early Liszt recordings was cited for fine virtuosity, so between that and the competition result, it would seem he should be able to deftly handle the technical aspects of the music. The fact that he studied at the Curtis Institute and Juilliard and worked or studied with Claude Frank and Rudolf Serkin also bodes well for his ability. So I came to his cycle expecting something at least well executed. Sheppard’s cycle was recorded live during a series of concerts in 2003 and 2004 in Seattle in the Meany Theater, so it’s up to date and modern, with whatever one wants to associate with that. As an aside, Sheppard’s website has an unusual error: it states that his is the only live cycle on the market today, leaving out Yukio Yokoyama’s, Andrea Lucchesini’s, and Georges Pludermacher’s to name three. It’s not really material; it’s just an odd and inaccurate selling point. Anyway, time for the music . . .
Way too close. The sound is way too close. The sound is dry and claustrophobically close – almost to the point of being oppressively in your face. It’s like one’s head is stuck under the lid of the piano. That was the very first impression I got, and it never abated. Tonally the sound is fine, though dynamics suffer a bit as will be mentioned later on. Beyond the too-close sound there is much to admire.
The first sonata opens with an Allegro marginally slower than I usually prefer, though the pace quickly picks up. It sounds a bit deliberate, but Sheppard will just dash off an arpeggio or otherwise impress with small touches of virtuosity. He never resorts to excesses of any kind. The part playing is also very distinct – aided by the close recording – with unique left hand accents frequently evident. The movement sounds a bit intense, a bit nerve-wracking at times. It’s not especially youthful or upbeat. The Adagio opens more smoothly, but then it’s back to a more intense, fraught approach. Sheppard deploys a number of little tricks here, like when he’ll cut short a chord for dramatic effect. Again, there is a nervous energy that permeates the playing. The Menuetto comes across as well-played, quick, with more of the tension evident in the first two movements, but still basically straight. The concluding Prestissimo starts with a finely judged overall tempo, bite, and growl. Here that’s most certainly a good thing. The section immediately after the opening material slows down and assumes a somewhat waltz-like beat audible in the left hand. The tension that has thus far been part of the recording remains, and Sheppard throws in some nice, purposely choppy playing that only increases the tension some more, especially in the repeat. Perhaps this isn’t my favorite take on the opening sonata, but everything works very well indeed.
Sheppard opens the second sonata in much the same way as the first. That is, the opening Allegro vivace opens just a bit on the slow side but quickly picks up, with Sheppard utilizing pauses and his rubato in a most successful manner. And again the bass line is quite distinct and steady. At times Sheppard veers toward an over-thought approach, but he always stops just shy of playing in an over-calculated fashion. The one drawback with the recording is the length; Sheppard takes the repeat, and he can’t make it work. It’s just too long. The Largo appassionato opens rather briskly, with an almost march-like left hand underpinning the music. Sheppard’s tone remains nicely rounded and appealing, despite the close sound, and the playing remains clear and never sounds hard. At times, Sheppard speeds up quite a bit and plays with great power in an impressive virtuosic display. Unfortunately, the too-close sound prevents his crescendos from assuming the heft and scale they deserve. The Scherzo is fast and sharp to open, with Sheppard maintaining a nice, pointed but not too sharp staccato much of the time thereafter. The middle section is fast and driven with more clear and choppy (in a good way!) playing. The ending Rondo benefits from all of Sheppard’s strengths, but sounds just a bit stiff at times. So, like the first sonata, this is very good if not quite one of my favorites.
The final sonata of the opening trio shows up the problem in the recorded sound again. Some of the playing in the Allegro con brio opener sounds almost blocky. That is, each chord is distinct and as a result the music doesn’t jell as well as it should – it’s an aural X-ray that reveals everything. After the opening bars, things do improve, and Sheppard once again displays impressive drive and power. The Adagio is taut and light at the open, with Sheppard moving the piece along with surprising tension. Low notes strike like thunder here (I was listening way too loud, I admit) yet they never sound even remotely hard or harsh. Beyond that, Sheppard’s ability to vary every aspect of his playing all at once really captivates. The man can tickle the ivories, that’s for sure. The Scherzo is quick, pointed, and jaunty, with a slightly malevolent air creating a sense of vigorous fun. The middle section is the thing here, though. Sheppard plays the bass part with massive, ponderous, and crushing power with an acid right hand burning one’s ears. It is pulverizing, but Sheppard never pulverizes the music. Sweet. The concluding Allegro assai is quick but not soaring (perhaps it’s the sound again), has some jolting (micro-) halts, and ends with a muscular display of pianism. This is the best of the opening trio, and one I know I’ll return to.
Moving on to the fourth sonata finds Sheppard opening with a very fast Allegro molto e con brio characterized by a scampering, almost twitchy right hand. The crescendos here sound fuller than in the earlier sonatas, and they are somewhat rich, as well. The playing just after 4’20” sounds feathery light – it’s really captivating – with the music that follows sounding more testy. One gripe is that the bass chords around 5’30” sound too spread out for my taste, but ‘tis only a quibble. The Largo is fast – at least when notes are being played. Sheppard uses the pauses expertly, and the quickness of the notes makes the pauses sound comparatively long even though they’re not. It’s a nice trick. The fiercer middle section is exactly that: Fierce. The Allegro, in contrast, sounds chipper and (for Sheppard) leisurely. The middle section has a nice rolling bass and Sheppard makes his Hamburg Steinway growl near the end. Sheppard ends the work with a Rondo that sounds at once lyrical and pointed. As things progress, the punchy left hand and taut right hand sound groovy, but in a slightly blocky way. The coda, though, flows along and ends the work in beautiful fashion. Four for four.
After four vigorous, muscular readings, I expected more of the same in the second trio of works. Instead, the first of the Op 10 sonatas offers something slightly different. The opening Allegro molto e con brio opens at a comfortable pace. It’s not slow, it’s just not shot-from-a-cannon fast like Claude Frank offers. The entire first movement sounds somewhat leisurely – by Sheppard’s standards – and if it assumes a quasi-orchestral scale, it still lacks some oomph. It does offer more of Sheppard’s unique pointed-yet-tonally variegated playing, though. The Adagio molto, while very strong when needed, sounds surprisingly warm and relaxed. Dynamics are somewhat muted overall, and it’s somewhat quick. Things end with a warmish, clear, rollicking, and fun Prestissimo. Not bad. For the second sonata of the group, Sheppard opts to play it light. Mostly. The Allegro is fun yet tightly controlled, with tasteful rubato and nice clarity. The Allegretto is tight, and somewhat quick, and the Presto (with repeat) opens at a sensible pace only to build up in both speed and power, though the coda doesn’t have enough snap. The second trio ends with the best performance of the bunch. Sheppard opens the work with a fast, pointed, and literal Presto. He doesn’t play with great breadth or depth yet plays seriously, to the point of sounding stern. Generally, that would be bad news, but not here. Sheppard forces the listener to believe! The Largo comes across as dark and bleak, which is good, but it never assumes a proto-106 Adagio feeling. Instead, it is unrelenting in its bleakness. That’s fine. The Menuetto benefits from big, rich bass playing and fleet right hand playing. To end things, Sheppard plays the Rondo fast, with some chords jack-hammered out, and ends the whole thing strongly.
Time for the perennially popular Pathetique. Not surprisingly, Sheppard opens with a pounded out chord to start off the Grave. The following music is hard-hitting, fast, urgent, intense, and angry, if not quite as loud as the opening announcement. The Allegro, also predictably, is played very fast, but it is also surprisingly unclear, at least by the standards set forth thus far. Some of the playing is diffuse, the runs somewhat soft and muddied, yet nervous, angry tension remains. It sounds like Sheppard may just get up and pimp-slap someone. Just before the coda, Sheppard plays more reflectively, more sorrowfully, and then he unloads on the listener. The Adagio sounds like a lament. It’s immediate and touching to start and switches over to a more idealized sound thereafter. Sheppard concludes the work with a direct, forward-moving, serious Rondo. Overall, this is an excellent version, yet it doesn’t quite match up with the very best. That’s hardly a condemnation.
Given Sheppard’s overall approach up to this point, I approached the Op 14 sonatas with a bit of trepidation. His muscular, pointed style, while compelling, could potentially make these pieces whither. That doesn’t happen. The first sonata opens with a quick, usually light, but sometimes meaty Allegro, moves to a somewhat lyrical but sometimes slightly too serious Allegretto and ends with a fast and serious but still fun Rondo. A world-beater it may not be, but it makes for fun listening. Better is the second sonata. Sheppard plays the Allegro in a warm, lyrical, and at times outright charming fashion. The Andante is pointed and poised, with the playing varying nicely between slightly quick and vigorous and soft and alluring. Sheppard ends the work with a light, lyrical Scherzo dashed off with panache. More good stuff.
But it is surely the meatier fare that matters more, and so I listened with keen interest to the Op 22 sonata. The Allegro opens in a generally fast and somewhat light manner, but Sheppard allows himself a lot of latitude here, really letting ‘er rip a few times and holding back ever so slightly – via shortened notes or chords or softer volume – at other times. The Adagio is again fast and light, with minute tonal variations and an insistent but never overpowering left hand underpinning. Overall, it’s dispassionate, but it is very well executed. As to the Menuetto, well, it seems that Sheppard likes to play this piece fast and light, and here his tone is quite ingratiating and his overall tempo, too, with the stronger middle section offering a nice contrast. Things come to a conclusion with an energetic Rondo, with some slightly cloudy playing offering a break from the X-ray treatment. It’s rather lyrical, too, and Sheppard brings the thing to a thundering close. Again, another fine performance, if not a front-runner.
The first eleven sonatas reveal Craig Sheppard to be an extremely talented pianist. He certainly has no difficulty playing the music the way he wants to. And what he wants to do is largely very interesting. His style is lean and pointed and muscular, and largely devoid of emotional excess. He’s classical and occasionally aggressive and always compelling. Indeed, he hasn’t delivered even one dog up to this point. That’s a good sign. I can easily hear why this set has received good reviews and praise from many people. However, Sheppard’s cycle is one of three modern cycles I’m listening to at present (the other two will be covered shortly) and I enjoy the other two even more. That I can write that just goes to show that LvB fans are not starved for choice.
