Whats a CDPS?
Posted by: Matt worlock on 18 July 2001
Sounds like An alternative to the XPS.....I didn't think there was one???
Please explain
Cheers Mad Matt ![]()
The CDPS was the power supply for the CDS1. Just like the XPS is the power supply for the CDS2.
Andrew
Andrew Randle
2B || !2B;
4 ^ = ?;
The reason why they are turning up on the s/h market is because of Naim's good PR exercise with CDS1 - ie. offering to convert them to CDS2 spec for £1600. CDS1 owners who do this are then likely to want an XPS, hence spare CDPSs. Nonetheless, so long as you are in possession of modified Burndy lead CDPS will work with CDX or CDS2 head unit; but be extra vigilant about switching everything off before disconnecting a CDPS - for technical reasons which Mark explained (and I immediately forgot), there is a very nasty discharge through the speakers if you don't.
I will post my opinions on CDX/CDPS/XPS soon.
Mad matt
I was advised that it is not really worth going from a CDPS to an XPS..as a cost effective upgrade..as is mentioned it is a considerable price difference even with a trade in.
However, I haven't had the opportunity of doing a comparison between the two as yet... but I am sure that someone on here has maybe done that and can report back.
Rest of the system comprises.. 52/Supercap/(Black Burndy)/2x135s/NBLs.
how long have you had the nbl's and how are you finding them? what speakers did you have before? apologies for being nosy.
enjoy
ken
Chris
I have had the NBL's for a couple of weeks now and in my particular listening room, concrete floor, fully carpeted, 17x12 feet, fairly well furnished, they sound very balanced indeed.
The whole frequency range from top through mid the bottom is so much better than before.
I have read that they can be rather forward and "in your face" sounding..but I have found no such problem in my setup.
It is a revelation going through old CDs and vinyls that havent been played for a while and listening to them afresh. The clarity is amazing.
The bass response is superb...and recordings with very deep bass ... cause no distress to the mid and upper drivers at all.
Give them a listen if you get the chance..at home on at least a weeks dem connected to your system.. they will sound different from the way they do at a dealers..of course..hopefully to their advantage!
Do you or someone else know the relative merits of CDS1 & CDX?
