AV2 Test Tone Problem
Posted by: HRC99 on 15 October 2005
Just in the process of trying to calibrate my AV2 a little more scientifically and trying to get the test tone going. It says ON but there's no test tone? Any ideas?
Posted on: 15 October 2005 by Steve2701
Had exactly the same problem...
You may just be going to go D'ooohhhh
Turn the volume of the AV2 up to over 30.. I used approx 50.
You can then calibrate it more accurately with a meter.
Posted on: 15 October 2005 by HRC99
Tried turning it up to no avail. Should it be on a particular input to work?
Posted on: 15 October 2005 by Jay
you gotta turn it to "on" right. then ya press the little i/p down button the once to select each speaker. that be what you not doing I would think.
J
J
Nearly! Press 8(down) then off you go. To be fair it was in the instructions but a little difficult to understand for a simpleton like me!
Off to play with it for a bit now!
The i/p down button does the same mate. Well least it does on mine.
Posted on: 16 October 2005 by General Skanky
Is that you Henry?
Posted on: 25 October 2005 by HRC99
Originally posted by General Skanky:
Is that you Henry?
Certainly is! Don't come here that often but just popped back to see what was going on! Small world!!! Cool
Posted on: 25 October 2005 by General Skanky
Yes it is. Smile
