52 PS
Posted by: Martin C on 30 December 2002
Hi there,
Need some advice from you guys.
I have seen a 52 Power supply on cheap. I am using 82 with single Hi-cap at the moment, I am not sure whther I can use the 52 PS for the 82.
As far as I know, 52 PS is dedicated to 52, as Burndy cable has to be used, please reconfirm, thanks.
There is also a 52 on cheap, but the serial no. is 66xxx, it was serviced by Naim though.
cheers
Martin
Posted on: 30 December 2002 by Not For Me
Doesn't have the sockets to power a 82. Too bad!
Can be upgraded into a Supercap for about £1,000 ish
DS
ITC Phillip Glass - Descent into the Maelstrom
Posted on: 30 December 2002 by Rockingdoc
The old 52 and PS bought as a unit could be ok, but not much use separately. Many old 52PS were upgraded to Supercaps, but this is quite expensive.
malcolm
Posted on: 30 December 2002 by Martin C
Thanks Dave & Malcolm,
What a shame!
The 52 is £2000 & the PS is £500, as I said B4, the serial no. are around 66XXX, but serviced by naim (don't know when?). Was it worth it?
I only bought my 82 & Hi-cap back a year ago, I may get the similar value for selling them? But would it be that different, new 82 to old 52?
cheers and happy new year!
Martin
Posted on: 30 December 2002 by Bosh
I was surprised how little difference there was between the 82/twin hicaps and the 52/PS (8xxxx series) when I upgraded in 1993. It got better with burn in, but the Supercap upgrade (£950) and the Pots board upgrade (£175 when the old one failed) took it into a different league.
A late 52/Supercap will probably only go for c.£3000 (£1400ish + your 82/Hi). My advice is to hold out for one of these or a Supercap for the 82.
Posted on: 04 January 2003 by Peter C
Forget the 52ps and go for a supercap.
An 82 requires a supercap before you hear what it really can do.
