mains spur clicks and pops...
Posted by: ken c on 17 January 2002
enjoy
ken
regards,
Mark
no. is this the missing trick?
mark, many thanks for responding.
enjoy
ken
The N805 tweeters clicked like mad when I revved up the lighting but then settled. When I added two spurs the tweeters got much quieter. Now I've changed speakers the clicks are louder again.
I have only noticed a noise as the lights are fired up, don't know if they degrade sound all the time whilst on. I may start a new 'fakey fart' scandal by a/b-ing lights on/off.
BTW no star earthing.
Alex
However, none of this will effectively eliminate the clicks and pops you mention, infact it is more than likely to make them more obvious. What you need is a mains suppressor or equivalent to eliminate these noises. Problem is, they usually eliminate the dynamics from the sound at the same time, so its a bit one or the other.
ah, so i guess i was wrong in assuming that a mains spur would eliminate these annoyances. i am not going to buy a mains suppressor as they also serve as very effective music suppressors - as you rightly point out. i hope to get round to installing a proper dedicated hifi mains earth this coming summer.
alex: i too have quote a few fluorescents in the house, but they are on a different (ring) circuit -- and i guess i was assuming that this woul isolate them -- i dont really fully understand this earthing business -- doesnt seem to be any consensus of views -- seems to be an art rather than a science.
mark packer, were you suggesting that a separate earth for my spur would do the trick?
enjoy
ken
jamzie, many thanks. will try this. hopefully my spur will not "see" whatever i install. its a bit hard to figure out how this wont affect things when the clicks travel all the way from a fridge (say) on an isolated ring to my sbl's at end of my system on a completely separate spur... phew...
enjoy
ken
Preferably by installing its own consumer unit as the first unit the mains power reaches as it comes into the home.
this sounds like its worth pursuing. i had kind of assumed that if you have more than one consumer unit, they would be "in parallel", so that there is no "first" consumer unit that power reaches as it enters the house -- sounds like i have the wrong model. will check and if there is need for this to be changed in any way, i'll have it changed. what we do for our hifi!!!
I'll be trying all this myself shortly to see how it works and I'll let you know how I get on. Interestingly in my last house I did have the Stereo circuit completely isolated as described above and I never - never - heard any kind of pop/crackle interference from other equipment in the house. So I'm hopeful.
yes, please let us know how you get on. i will also be trying a few things and will report anything significant i find.
enjoy
ken
Originally posted by lobo:
It seems that you lot are saying noise travels along electrical wirings, but I always thought the click and pops you hear are caused by air-borne RFI generated by other appliances (fridge, flourescent light starters, etc.)? If this is the case, it explains why you still have interferences even if you have a separate hifi spur.
Lobo
From the "Fragrant Harbor" ! You mean flourescent light starter problems are air-borne ?
Anyway, if that's the case, how do you change the fluorescent light starter into something that won't cause problems ? Is there any alternative to them, besides changing the lighting designs ...
It will have its own dedicated switch box which will be first in line after the meter and before the main house unit. It will have 10mm2 cable into an unswitched MK socket.
I was advised that this was the best way to go about it, rather than run a spur from a spare switch in the main box.
I have to say though, that I get no pops and clicks on my system even now on the ring main... apart from in phono mode using a MM cartridge and then only very slight.
I will do some tests when the new spur is running and let you know.
will report if i stumble on anything significant, but these problems tend to be very specific to location - so my experience may not easily extrapolate.
enjoy
ken
I've tried the Audioprism QuietLines. Damn if the dynamics were squashed !
So now, will try to look for the electrician who did my older one ... Michael's solution is something to investigate as well.
BTW, when you said air-borne, I remembered what the new electrician said, that the clicks and pops are airborne and caused by the fluorescent starters. A hifi dealer said it's not ...
[This message was edited by JosephR on SUNDAY 20 January 2002 at 02:15.]
Alex
1. My system is in an upstairs room almost directly above the consumer unit. So the cable run to the HiFi is very short. (and doing the separate spur was a doddle
2. The 5 series stuff (112/150) is less susceptible than the 3 series.
3. My appliances are well suppressed from causing this type of interference.
Hope this helps.
Steve B
Originally posted by ken c:
i had assumed that a mains spur would eliminate those annoying clicks and pops that you hear through speakers whenever the boiler, or fridge, or ... switches
Ken,
you may be interested to know that my system is giving slightly louder pops and crackles since replacing my NAXO with SNAXO - it seems to be more open to this sort of thing.
cheers, Martin
Originally posted by Jamzie C:
Rather than adding something to supress the problem (ie by fitting a 'hifi' mains filter), it's far better to solve the problem at source. If you've (say) a fridge that's creating noise, then fit a cheap mains filter onto this.
Jamzie,
it doesn't matter where in the circuit you put the filter, it still appears electrically across all items on the ring, and to some extent on other rings, too.
cheers, Martin
i suppose you are not bothered. i doubt if sound quality is affected at all -- its just annoying to hear these noises every now and then, especially at night when i listen more deeply.
martin, many thanks...
by the way, before i forget, i meant to ask you -- i believe you have a prefix -- how do you have it connected, via hicap to bnc? or via 4 to 5 pin din to one of the high level inputs ? or using 52's power to 52 input 2b. as i have reported before, i find input 2b connected has the least RFI, almost non existent in my room -- i guess i could have got these answers from your profile -- just lazy -- sorry.
enjoy
ken
No worries.
Stageline, actually.
Actually, although I have a demo Stageline S in my system, my spangly new Stageline K should be ready to collect from my dealer next week sometime.
He should have ditched those abhorent phono sockets in favour of BNCs, too!
HiCap to BNC? BNC???
Major loss of FEPs for suggesting a connection strategy which breaks the earthing rules! The two separate cables will form a (small) earth loop.
Also, BNCs are a suitable impedance for a cartridge, not a pre-pre-amp to pre-amp connection. DINs are suitable for this.
On top of this, the signal has to go through straight-through boards, and it's better to go into a hard-wired socket instead.
HiCap? I wish.
It's powered off input 2b.
Actually, the main reason for getting the Stageline (not including sound quality) was that the double run of cable (arm lead + SNAIC5) lets me get the LP12 much further away from the rest of the system. Big benefits to sound quality from this.
HiCap would help even more here, too. Hmm, or would it? RF is something I don't need.
Small amount here with the 'S' model into 2b. We'll have to see with the 'K'.
cheers, Martin
[This message was edited by Martin Payne on MONDAY 21 January 2002 at 02:45.]
For info, I called Naim about this today, and the SNAXO should be LESS susceptible to this sort of thing.
cheers, Martin
did you have a chance to ask why? i.e. what have they done to minimize this in snaxo -- an answer to this may help us with insulating our installations against this annoyance.
anyway ...
enjoy
ken
Ken,
dunno. I will swap the NAXO back - if it reduces the problem then they have asked me to return the SNAXO for another check-over.
cheers, Martin
Of greatest interest to me was the Electronic Starter to replace the ones currently in my fluorescent lightings. According to them, there is no other way to cure clicks and pops from the starters, except by replacing the starters with electronic ones. This is what I was looking for, and it makes sense, and should not degrade the sound at all. Will be ordering and find out ...
[This message was edited by JosephR on WEDNESDAY 23 January 2002 at 19:39.]
please let us know...
enjoy
ken
