Please play this Naim Game
Posted by: Jeb on 27 November 2000
Put the following pieces in the best sonic order on a 4 Shelf stand? Which 2 pieces could be on the same shelf and in what order should they all be from top to bottom.
CD3.5
Flat-Cap
102
Hi-Cap
180
Shelf 1 -
Shelf 2 -
Shelf 3 -
Shelf 4 -
FLOOR
Thanks!
Jeb
Posted on: 27 November 2000 by Former member
Jeb,
102 on top
cd3.5 next
Hicap next
Flatcap & 180 on bottom
Or alternatively, junk the 4 shelf stand and buy yourself a Mana 5-tier. Also, you should add the almost mandatory NAPSC for your 102. If you can't afford a 5-tier, at least get yourself a Mana Soundtable for the cd3.5. You'll be very surprised with the difference it makes and that will leave room on your 4 shelf stand for the balance of your electronics.
James
TOP
Hicap
NAP180
]]]]]]]]]]]<--shelf
Flatcap
]]]]]]]]]]]<--shelf
NAC102
]]]]]]]]]]]<--shelf
CD3.5
]]]]]]]]]]]<--shelf
BOTTOM
Posted on: 27 November 2000 by bob atherton
1..... 3.5
2..... 102
3..... f/cap h/cap
4..... 180
Posted on: 27 November 2000 by Andrew Randle
Answer 1)
180
flatcap
*1st Shelf*
HiCAP
*2nd Shelf*
102
*3rd Shelf*
CD 3.5
*4th Shelf*
Answer 2) fork out for another table!
Andrew
Andrew Randle
2B || !2B;
4 ^ = ?;
