Acheing Feet, a solution sought.
Posted by: syd on 16 April 2004
Hi All
I've just started a new job working 12 hour shifts and almost continuously on my feet. The work environment means that their are no seats readily available. After the first three days my feet were really acheing and I wondered if any of you know of any good advice for foot care. I enjoy the job but find that after about 7 to 8 hours the pain in my feet is really distracting. You start to think more about the next break so you can rest than about the tasks your doing. Any advice gratefully accepted.
Yours in Music
Syd
Yours in Music
Syd
Posted on: 16 April 2004 by Former member
Prevention is better than cure - get some good quality shoes. I also move around a lot during the day and had the same problem. You don't need to spend a fortune, just try on as many as you can until you find the ones that suit you. It's worth it.
Sean
Sean
Posted on: 16 April 2004 by garyi
I work in catering, if I am lucky I can sit down for a break at lunch. We serve a warehouse which has 33 vending machines it covers over a mile. We also serve lucnh to around 400 each day.
Basically I am on my feet for most of it, at the end of the day I am knackered. Sometimes I work 8 hours (rarely) sometime I work 12-13 hours.
I am sure that 30 years ago, forums were not available and men had to take work like men, pull yourself together!
My feet ache, jesus!
Posted on: 16 April 2004 by Mike Hanson
Get yourself some good shoes with padded soles and supportive uppers. Add to that a pair of Orthotics (which are good for more than the flat-footed among us), and you'll be set.
-=> Mike Hanson <=-
-=> Mike Hanson <=-
Posted on: 16 April 2004 by ErikL
1. Good shoes.
2. Foot massages from your significant other.
Posted on: 16 April 2004 by ChrisD
try a pair of sorbothane insoles.
Posted on: 16 April 2004 by nodrog
Get some of those weird sandals with the knobbly insoles. They hurt a bit at first and your colleagues will look at you strangely. But, they are fantastic.
Peter
Peter
Posted on: 17 April 2004 by syd
Thanks for the suggestions so far. I should have mentioned that the environment is a clean room and footwear is dictated by the company. But the insoles sound intrigueing and what are Orthotics Mike?, never heard of them before. One other thing I should mention is that I'm standing around tending 3 to 4 machines and therefore not walking about much, which is a pity as when I'm on the move the pain isn't as severe. It's the standing about in the same place for ages that's really a pain in the ar...foot. Thanks again.
Yours in Music
Syd
Yours in Music
Syd
Posted on: 17 April 2004 by Markus S
I had a job like that once. My solution was to walk constantly, but to make the steps very, very small, or to stand still but work my toes.
You do get used to it after a while, but I'd support the recommendation of orthotics (= insoles).
Posted on: 17 April 2004 by DAVOhorn
Hey this is my territory!!!!
I am a Podiatrist working for the NHS here in deepest darkest suffolk.
May is suggest that before you buy Sorbothane insoles you consider what sorbothane is and does.
It is superb at shock absorption ( that is why it is used in HiFi) but is lousy as an orthotic. Even if shaped. It provides no functional control of the foot during the gait cycle.
If your symptoms are caused by simple mechanical trauma eg shock during heel strike then Sorbothane is the way to go.
However if this is not the case then may i suggest that you find a State Registered Chiropodist/Podiatrist who specialises in Bio Mechanics and have a Bio Mech assessment to see if there is any abnormality in your gait cycle.
If there is then an orthotic is indicated.
If you go to BOOTS they sell the Vasyli Orthoheel which are OK but are not really man enough for the job. Insufficient functional control to prevent the recurrent minor trauma that you are experiencing at work.
So a casted orthotic may be the way to go.
Cost is significant though for the Bio Mech assessment and the taking of the cast and provision of the orthotic to prescription.
Very similar to prescription lenses from an optician in fact.
Would be very interested to know how this pans out.
regards David
regards David
Posted on: 17 April 2004 by blythe
You might care to have a look at this site: http://www.foot.com/
Computers are supposed to work on 1's and 0's - in other words "Yes" or "No" - why does mine frequently say "Maybe"?......
