Mains power
Posted by: murphydog on 24 March 2004
Can anybody recommend an inexpensive mains block?Anything would be an improvement on my rather adhoc existing arrangement!
Posted on: 24 March 2004 by andy c
Oooh you'll start something off on this forum talking about mains blocks! Eek
Main (doh) purveyors seem to be musicworks, or you could get a hydra (Grahams gets talked about alot here), or you could go the whole mains spurs way and max it!
how many plugs are involved?
andy c!
Posted on: 24 March 2004 by prowla
earwig
earwiggo
earwiggo earwiggo
ear wi go ear wi go ear wi go
here we go here we go here we go here we go here we go here we goOOoo here we go here we go here we go here we go-o here we go
make up a hydra and save some money.
Paul
Posted on: 24 March 2004 by murphydog
I'm sorry if I've opened a can of worms but could someone fill me in re hydras and their pros and cons its all new to me.
Right - 'ere goes....
a) Using a 4-way block you have: wall socket - mechanical plug connection - fuse in plug - screw terminals in plug - 2m cable - screw terminals in plugboard - possible internal fuse in plugboard - possible more internal connections in plugboard - possible LED in plugboard - plugboard sockets - equipment cable plug physical connection into plugboard socket - fuse in plug - screw terminals in plug - 2m cable - screw terminals in IEC plug - IEC physical connection into equipment.
b) With a Hydra you cut out most of the connections, giving : wall socket - mechanical plug connection - fuse in plug - screw terminals in plug - 2m cable - screw terminals in junction - 2m cable - screw terminals in IEC plug - IEC physical connection into equipment. You can also more easily use the same type of cable (and in the same direction too!). Grahams make a Hydra using original Naim mains cables (which some say sound best anyway.)
c) A variation on a hydra is to have several wires coming out of a single wall plug (Maplin sell a suitable plug).
d) Some people try and lose all fuses, relying on the mans circuit's circuit breaker (MCB) to protect them.
e) Some people re-wire their mains with higher grade cabling, and use bigger plugs for a better contact.
And that's only the start of it...
Paul
Posted on: 24 March 2004 by Basil
How long can it be before we get people moving to be closer to a power station????
Posted on: 24 March 2004 by Midun
Or get dedicated home generators? Or Naim-only hydrogen fuel cells? Or hook their "kit" (as you Brits call it) up to their exercise bikes? (Just having some fun here.)
Posted on: 24 March 2004 by Laurie Saunders
It`s already happened Big Grin
Laurie S
sounds good my email p.neeveatntlworld.com
Posted on: 24 March 2004 by Alex S.
Nick Lees managed to get the local sub station moved closer to him!
Okay,okay.But that is about the level I'm at at the moment,however I have a thousand and one potential upgrades to make since I started visiting this forum and all because I blew the dust off my naims in the attic!
Posted on: 24 March 2004 by Geoff P
You did what!!!
How dare you abuse you're NAIM like that.
You realise that one of the tweaks recommended on this froum is to allow a patina of dust to grow on the boxes. It reduces microphony.
Of course that does'nt apply to the front panel which is specially designed so 'er in doors can polish it!
Posted on: 25 March 2004 by Laurie Saunders
I thought of it first! Big Grin
Laurie S
Posted on: 25 March 2004 by roger poll
Andy c,
Please check your private topics.
Roger Poll.
