PC Virus Scanners - Which is the Best?
Posted by: David Stewart on 26 March 2004
My existing version of McAfee (V4) is now no longer supported, so I need to upgrade or buy another anti-virus product.
McAfee ViruScan 8.0 looks pretty good and is the default option, but before commiting the credit card, I thought I'd ask for other forum-users experiences on this and other virus scanners.
So let me have your views and recommendations on anti-virus software you use.
Posted on: 26 March 2004 by seagull
I used to have MacAfee on my home PC but it caused more problems than it solved. It seemed to interfere with everything and made the pc run like a three legged dog.
I now use Norton - which has intercepted everything those b******ds have thrown at it so far.
Posted on: 26 March 2004 by Former member
I use Norton at home - seems pretty effective and I have never been a victim of something unpleasant.
A client used Norton on their n/w and a bagel variant got past it and caused mayhem. Now they use Message Labs service and Sophos on the desktop. Belt and braces, innit.
There was a thread on the freebie AVG software quite recently - that seems to be well thought of. And it costs nowt.
ag
ag
Posted on: 26 March 2004 by TomK
I use Trend PC-Cillin at home and at work we use Vantage Virusguard. I've never been infected at home and at work where we have a network of 1200 PCs, 400 staff and thousands of students we've never once had anything get through which is quite an achievement.
Posted on: 26 March 2004 by Andrew L. Weekes
Norton is effective, but bloated and slow.
I've been eyeing up NOD32 recently (www.nod32.com), it's a very good price (22 quid for 1 year, 33 for 2 etc..) and is written in assembler; it's therefore smaller and faster than some of the bloatier options.
Reports from users are that it consumes far less resources than most and scans very quickly.
I'm going to try it once my existing Norton subscription runs out.
Andy.
Andy.
Posted on: 26 March 2004 by Pictish
I use the free edition of AVG. Seems to do everything the others do, is easy to use and best of all costs nowt.
http://www.grisoft.com/us/us_index.php
Mike
Mike
Posted on: 26 March 2004 by David Stewart
Thanks guys - very interesting so far, but even more confusing, as there's clearly a lot more options than the mainstream products I've looked at so far.
Obviously there are mixed feelings here about both NAV and McAfee, which seems to tie in with reviews elsewhere. On balance though reports I've read suggest that NAV2004 slugs the system far more than McAfee - Mmm the jury's still out!
Mr Seagull Sir,
Which version of McAfee did you have? I had problems with V4 Virus-Shield slugging the system, so I disabled it and just rely on daily overnight scans which have been doing the job OK.
Mr Seagull Sir,
Posted on: 26 March 2004 by matthewr
I don't use any AV software and have never had a problem with a virus.
This approach is free and uses zero resources.
Matthew
Matthew
"Which version of McAfee did you have?"
Afraid I don't remember. It came with the PC (about 3 years ago), I soon replaced it.
Matthew, if it were just Mrs S and myself using the pc then I would not bother with AV software either - but I have kids!
Posted on: 26 March 2004 by Phil Barry
I stopped using and recommending McAfee on 2 counts. Most important, a reboot was required after too many updates. Second, they inundated me with ads.
I was a committed Norton customer, using SystemWorks Pro through the 2003 series. Unfortunately, the 2004 version is a pain in the neck.
Their DRM too often fails, requiring a lengthy call to Norton for a fix. The product itself seems to need periodic reinstallation, which furtehr seems to screw up their DRM. Worse, a support call costs more than their product.
Next time, I'll look into AVG, and Trend-micro, which was the first vendor to provide a free online scan.
For business, I'd look at - and probably buy - Sophos.
Regards.
Phil
Regards.
Phil
quote:Trouble with this method is it relies a lot on luck, discipline and knowing what you're doing - not really to be recommended for most (fallible!) folk I feel - a bit like relying on the rhythm method for contraception
Norton is very good, but does have upgrade issues. Some clever scripts can stop it automatically updating its virus settings and even turn the program off.
I find XP firewall with Norton a good combination, though not perfect. But what is these days?
Posted on: 26 March 2004 by andy c
I use Norton firewall/antivirus etc. I have had no probs with it, and its saved my bacon a number of times...
andy c!
andy c!
Posted on: 26 March 2004 by Rockingdoc
I use the Norton suite and like it (apart from the cost).
The no protection but ghost backup to a removable hard drive is another way to go.
Matthew
Be careful these don't turn out to be famous last words. To use the Internet without adequate protection is not only dangerous to yourself, it's downright irresponsible to those you're in regular contact with. You could well be emailing viruses to your friends without knowing it. It's not a matter of just being careful which sites you visit as viruses can appear anywhere, even on the sites of reputable suppliers, disks free with magazines and often the most unlikely of sources.
I would advise you to get some sort of antivirus and firewall in place before it's too late.
In my professional opinion I disagree. 99% of all computer viruses will not effect computers which are properly maintained and operated and I do not believe it's worth £30 a year (or whatever) and the processing/annoyance costs of AV software to get the last 1%.
Its not an approach that suits everyone but I remain unconvinced that I am facing much in the way of actual risk.
Matthew
Matthew
Posted on: 26 March 2004 by Paul Ranson
I concur with Matthew.
Paul
Paul
Posted on: 26 March 2004 by JeremyD
People who are knowledgeable, incapable of making mistakes and willing to tell friends and relatives "Sorry, I deleted the attachment you sent me in case it contained malware" may be safe without AV software. The rest of us would be irresponsible not to use it.
I am currently being deluged with virus-containing emails and occasional complaints from people who think I've sent them a virus - all thanks to someone somewhere in France not using an AV programme...
Re AV programs: I use Norton 2002 (with a current update subscription) but its ergonomics are very bad. I tried AVG recently but rejected it for some reason that I've now forgotten. I think I'll have to try it again to remind myself why...
Posted on: 26 March 2004 by Kevin-W
I know I'm gonna get slagged off for this, but, well, who cares?
If you used a Mac you wouldn't be plagued by viruses. Admittedly, at work we are protected by a firewall (we are a Mac environment) and I've never had any trouble.
At home, I've used a Mac since 1991, and have been online since 1998, and, despite a lack of virus software or a firewall, have never been plagued by any infections...
Otherwise, it's down to good practice. Never open any attachment from anyone you don't know, and be suspicious of weird suffixes on attachments. Matthew is also correct in his assertion about AV software...
Kevin
Kevin
Posted on: 26 March 2004 by John Sheridan
this is the sort of thing that av vendors want you to believe. Unfortunately, however, current av programs are completely useless as they are incapable of detecting virii until their signature files have been updated. Therefore, anyone who's in the habit of clicking on attachments is going to get stung, av software or not.
Posted on: 26 March 2004 by Thomas K
Therefore, anyone who's in the habit of clicking on attachments ...
Isn't that just about everyone? I have to open my clients' attachments, otherwise I'd never get any work done.
True, of course. FWIW, Norton prompts me to update the signature files about every second day. I have no idea how useful the updates are, though.
Thomas
Thomas
Posted on: 26 March 2004 by Jez Quigley
How do you know your machine is not infected? A virus/trojan could be silently using your machine for all kinds of nefarious activity e.g. denial of service attacks and harvesting of personal details.
"How do you know your machine is not infected?"
I don't. But I bet you a million pounds none of my computers are infected with anything.
"A virus/trojan could be silently using your machine for all kinds of nefarious activity e.g. denial of service attacks and harvesting of personal details"
Only if I had made at least two gross errors that I am not likely to make.
Matthew
Matthew
quote:Absolute nonsense. The likelihood of receiving an existing, detectable virus that is only prevalent because not enough people are using AV software is far higher than the likelihood of receiving a new, so far undetectable virus.
To the best of my knowledge, I haven't had a computer infected since 1990, when I lost a week's work due to a virus.
Posted on: 27 March 2004 by Paul Ranson
You receive the same email. And the same irritation. Two more just now.
But I've never seen one that I'd be tempted to think was really an attachment I should be opening.
Paul
Posted on: 27 March 2004 by matthewr
Oddly enough I recieved a couple of viruses this morning and it's slightly annoying in that one of them came to my actual e-mail address which I guard very carefully to keep it spam free.
The other one was very odd as it came to a made up variant of my address which doesn't exist but requires you to know my full name. I wonder if this means that viruses are harvetsing e-mail addresses from whois entries or something.
Matthew
Matthew
