Powerigel
Posted by: Juliandowd on 12 February 2005
A few months ago I started this topic:
http://forums.naim-audio.com/eve/forums/a/tpc/f/48019385/m/480100362/r/143104682#143104682
Now I installed a Powerigel 11 in my system.
Everything changed.
What a improvement.
One of the best upgrades I did the last years.
Best regards
JD
Everything changed.
What a improvement.
Best regards
JD
Posted on: 13 February 2005 by sjust
Hi JD,
I remember chatting with you about my "beta phase" with the Igel. Glad to hear that you confirm my findings. I wouldn't want to go back (or sideways), and am very happy with the cute little animal...
cheers
Stefan
cheers
Stefan
Posted on: 15 February 2005 by DF
what is:
POWERIGEL ???
POWERIGEL ???
and how much is powerigel?
and is it Naim approved?
and is it available anywhere else besides Germany?
Posted on: 15 February 2005 by Exiled Highlander
Posted on: 15 February 2005 by London Lad
It is a hydra. I had one last year. It didnt do anything in my system so I sold it.
Posted on: 15 February 2005 by mtuttleb
Powerigel is a product of the Naim distributor in Germany (musicline).
The benefits of the product are given in the previous link
I don't have one (I do have 2 separate 10mm spurs though) so I can't tell you the benefits.
Mark
Mark
Posted on: 15 February 2005 by sjust
Juliandowd,
will you eventually tell us about the SNAIC that you successfully bought on ebay (leaving me with empty hands
All being said about above the PowerIgel is right: Sort of hydra, sold only in Germany (which makes kinda sense because of the power connector used). Price range (depending on the number of power cords) between 600-800 EUR.
Sound benefits in spades.
cheers,
Stefan
cheers,
Stefan
It is available in the UK as well. Contact musicline via their web site and they will refer you to their UK distributor.
However I would reiterate that in my system it made no improvements whatsoever.
Posted on: 15 February 2005 by uem
Dear Colleagues,
I recently started this thread,
http://forums.naim-audio.com/eve/forums/a/tpc/f/48019385/m/55910812/r/55910812#55910812
I'm still not convinced that users in Switzerland, Germany or maybe other non-UK countries do really get THE original Naim power cord - the cord types suggested in the replies do not match the cords I got with my Naim gear (Mind you I'm using Audio Agile for quite some time now)
So I'm not surprised, that UK Naimies get no improvements by changing their original Naim cords.
However, for us "Continentals" the story is probably different: If the PowerIgel does indeed use original Naim cords, it could well impove over the stuff we get here.
So far I haven’t received any feedback from Naim regarding the type of power cord delivered with their gear outside UK.
Urs
Urs
Posted on: 16 February 2005 by Juliandowd
Juliandowd,
will you eventually tell us about the SNAIC that you successfully bought on ebay (leaving me with empty hands) ?
cheers,
Stefan
Hi Stefan,
what do you want to know about that?
JD
Posted on: 16 February 2005 by sjust
Hi, JD,
I just wanted to know about your findings after you exchanged the grey SNAIC with the black one you've bought. I followed the auction, but was only prepared to spend less money than the final price, also, because I normally only buy things after auditioning.
So, please report about your findings, and help me to make a decision on upcoming ebay auctions...
Thanks !
Stefan
Thanks !
Stefan
Hi, JD,
Thanks !
Stefan
Hi Stefan,
sorry, for what I do now in this forum, but my englisch is not as good to describe the differences between the grey and the black snaic.
So I will switch to german only for a few sentences:
Ich denke, das Kabel, welches du meinst Stefan ist das 4 Pin Snaic. Dieses habe ich noch nicht bekommen. Ich bin selbst gespannt, was es ausmacht. Ich bin gerade dabei meine gesamte Kette von grauen auf schwarze snaics umzustellen und jeder Austausch brachte die Kette minimal nach vorne. Der Unterschied wurde umso deutlicher, je weiter vorne in der Kette der Austausch stattfand. Letztlich ist es ein wenig mehr Kontrolle und deutlich mehr Fluss in der Musik. Was es aber viel mehr gebracht hat ist der Austausch meiner alten Sun Leisten gegen den Igel. Da war ich wirklich platt.
Schönen Gruß
Fred
P.S.: Gibt es eigentlich das "Private Topic" Modul noch. Denn ich glaube, wenn ich hier meine Eindrücke auf Deutsch wiedergebe, kommt das auf Dauer nicht so gut.
P.S.: What is about the "Private Topic Feature" in this Forum. Was it vanished? I can´t find it?
Thanks, Fred !
If you like, put your findings (once you've received the black 4 Pin Snaic) into a German language mail to "sjust at borland dot com"
Ebenfalls schönen Gruß !
Stefan
Stefan
Posted on: 16 February 2005 by JonR
Fred,
Private Topics were removed as part of Adam's forum overhaul.
Hope that helps.
JR
